Global West Upper arms
Noticeable straight line tracking difference? What caster angle alignment did you end up with?
I do not have access to a mill to slot the upper cross shaft as some have done, and really don't trust the local shops around here to even try that.
And I can say the owners LOVES how the car handles.
If you need to hear it from him....PM '1974CorvetteJimCr'
DUB
If your stock suspension is going to be rebuilt completely you will notice a big difference without any aftermarket parts. With a proper alignment and new parts it will drive just fine.
Del-A-Lum works like a bearing but its a bushing! Del-A-Lum bushings feature inner and outer thrust washers, inner rotating sleeve and lube fittings. This unique design provides smooth performance without squeaks or bind. Designed to last over 100,000 miles.
I highly recommend them without reservation!
The other side of the proverbial coin,..if technology advances make gains,...why replace with just stock. The roller cam everyone runs now for example. Back in the 60's L-88 427's made over 550 horsepower with flat tappet solid cams. Today everyone thinks to make 550 horsepower you can't do it without a roller. You can,....but in comparison the old design is a cave mans version.
The idea of more camber would bring the caveman front end more in line with a modern suspension? Or is it just marketing trying to sell fancy looking parts.
The global west bar appears to be thicker and someone posted how it increased camber.
I did that post on making my own slots on a vert mill of about a 1/4 inch or 6-7 mm I have 6.5 castor. It really helps with modern tires
If you plan on going 85+ MPH get as much as you can.
I went from 2.75 - 4.7 degree's and I didn't notice any difference. 0 - 70 MPH. But I have poly everywhere, vbandp street and slalom complete kit. Does it drive like my 2010 C6 GS, not even close.
Getting a proper alignment with tight suspension all around should be the goal to getting a great street driver. Properly adjusted wheel bearings, very little rotor run-out etc.
I put in everything new and always felt that the steering box was lacking So I had our CF steering box man refurbish mine. It still can't compete with some of the power R P vettes that I have driven
My next step is a great power R P kit. I just don't know what is the best
And you don't need to go 85 mph to feel the benefits of increased caster. Here's a good article if you really want to understand the effects of caster.
The Ultimate Handling Guide Part VIII: Understanding Your Caster, King Pin Inclination and Scrub
Adding positive caster: (from the article)
• Generally improves straight-line stability, ( driving fast enough YES )
• Sharpens turn in. ( needs to be extreme )
• Improves traction everywhere in the turn. ( not on the street )
• Improves steering feel ( possible if way off )
• Improves self centering and self steer effect. ( if you drift )
eg blind test: ask the driver to take a test drive. Then make a castor change eg ( 2.75 - 4.7 ) then ask him to test drive again. His / Her response , it handles much better , feels better , I like it. Then to burst their bubble and tell then "you changed nothing"
Can you notice the difference in a car with better geometry. eg C3 vs C6 corvette, "yes" but only making 1 change caster in a C3 I will go with the blind test results.
If you use your car for track days please read the article. This effects you.
If you want the "wow"
factor fix your suspension / alignment back to factory "NEW" condition. Get a proper alignment and go from there.If your frame doesn't allow you to get proper caster then you need to look at other options (street use ).
For track day guys get something like SPC arms where you can adjust camber / caster in the arms.
To fix frame problems for street use Global West or similar solutions like slotted arms etc. (cannot get 2.75 caster)
As I remember with my Savitske upper arms, there was a tall ball joint option which I selected. I don't remember the details but in thinking about it this morning with my coffee, it would seem to put the upper and lower arms more in parallel and change the vertical camber gain. That would probably reduce (I'm guessing here) camber thrust on uneven roads and maybe make the ride a little more comfortable.
tighter side to side response with the wheel straight.?
Not sure what feeling changes I would expect ?
But that is not street use. with 2.75 caster.I guess uneven roads could be a noticeable effect (usually affected by cross castor / camber not even side to side), but most complain about this type of wandering because of poor suspension / alignments and not adding additional caster (past 2.75) for improvements.
Guldstrand's mod drops the centerline of the mounting bolts 3/4 inch, and shifts the pair back 1/4 inch. Drill two holes,....have mod. Sounds too easy for nobody to have tried.
The roads here in Pa. are not much better than oiled cow paths for the most part. and so yes,...the car does follow ruts. If I find a way to make the car track more solid, that's my end goal. The rebuild will also incorporate all new bushings and joints, that's a given.
Taller ball joints.....hummm...Will that help and eliminate drilling the frame?
