Did 1980 Corvettes come stock with tow hooks of any kind front and rear ? Would the two square bent steel box like pieces at the rear bumper work for towing or are these for another purpose ie : to obsorb impacts, exhaust mounting etc ?
Any photos that you might post would be appreciated .
Best.
Robert - five years into my first build /rescue and still have much to learn .
...Did 1980 Corvettes come stock with tow hooks of any kind front and rear?...
No. To my knowledge, no C3s had towing provisions.
...Would the two square bent steel box like pieces at the rear bumper work for towing or are these for another purpose ie : to obsorb impacts, exhaust mounting etc?...
the railroad had special links with a T-shaped piece that went into that slot for tying them and most other vehicles of the era down for shipping. I have a bucket full of them
Modern Cars that have screw in tow Hooks used them for the Boat ride to America from wherever they were made. Cars made in Saint Louis didn't need them. To strap my Car down I use the lower A Arms and the Batwing. However I am considering trying the Netting that I see Tow Trucks using that fits over the Tires. Looks like a pretty good way to do it.
just curious if any of those would be for sale?
Thank you
text at 2692759335
Thank you
text at 2692759335
they are in my FIL's barn, we kind of share them since he got them when he worked on the RR. when he gets back from wintering out of state i'll see if I can get a few.
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Originally Posted by Robert Butler
Gentlemen,
Best.
I know what you mean on these, I have them as well and took mine off a long time ago, extra weight. However, I do install them when I go to the dyno with grade eight bolts and use to strap it down. Even the assembly manual doesn't really tell you what they are except brackets. You would probably tear up the rear if you towed with them. I would put it on a trailer or flatbed if you are taking it somewhere. Good luck.
