Leaking Heat riser question
Old Oct 18, 2016 | 09:48 PM
yyz1970's Avatar
yyz1970
Default Leaking Heat riser question
I have removed my passenger side exhaust manifold on my stock '72 350 to fix an exhaust leak at the Heat riser.
There is no sleeve in the pipe to center the donut...should there be?
My AIM on shows one on the drivers side?
Thanks for the help
Old Oct 18, 2016 | 09:52 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There should be sleeve in both sides at the header pipe, and a flat gasket between the riser and the manifold.
Old Oct 18, 2016 | 09:56 PM
yyz1970's Avatar
yyz1970
thanks, I will see if the local muffler shop can make me one
Old Jun 27, 2021 | 07:40 PM
therunningman2012's Avatar
therunningman2012
Default 77 heat riser leaking also
Hello all. I’m seeing the same issue. Today I put the car up on blocks to start looking at options for mine. Watching this thread for advice.
I’m faced with same dilemma. Should search the Internet for a spacer which I have yet to find for a 77 or replace the gasket and or donut as needed.
also something else I noticed this evening when I crawled under it. It looks to me as if the exhaust manifold has a few cracks in it. But I cannot tell if they go all the way through or not. It may be they are just on the outer edge.
Please look at attached pic and give advice.
thanks all.
Old Jun 28, 2021 | 12:23 PM
7T1vette's Avatar
7T1vette
Someone has put thick head-to-manifold gaskets in there...and then cranked the he!! out of the bolts to crack the casting. Not sure what issue they were trying to fix. With engine idling, see if there is any exhaust coming our of those cracks. If not, ignore them. If they actually leak exhaust, replace the exhaust manifold.
P.S. GM did not put gaskets under those cast iron manifolds. The heads and the manifold surfaces were flat enough to seal leakage.
Old Jun 28, 2021 | 12:35 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
thanks all.
My 77 didn't have a donut or sleeve on the passenger side. New exhaust manifolds are cheap but getting the old one off can be a challenge with bolts snapping off.
To Leaking Heat riser question
