I have never been able to find a good illustration showing where these brackets attach on the engine side. They almost look like they line up with bolts that hold the intake manifold; surely you don't take out those two bolts to attach these brackets? Then just reinstall the two bolts? Thanks!
Hi k,
Here're the bracket locations on a sb.
On a small block the positions of the brackets is important so that the distributor shield clears the wiper motor/washer pump, and the right side bracket clears the vacuum advance can.
Regards,
Alan
