dumb question about splines
Old Sep 17, 2002 | 01:12 AM
gravismaximus's Avatar
gravismaximus
Default dumb question about splines
im getting ready to buy a richmond 6 speed for my auto 81, so i have to but a a flywheel, clutch, etc... however i see that i can get a 10 or 26 spline, which one is better, and why. also any recomendation's on what clutch, etc i should get to go with this tranny, thanks
gravismaximus@aol.com
Old Sep 17, 2002 | 01:16 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: dumb question about splines (gravismaximus)
I have a ROD in my 69, you will love the tranny. Get the 26 spline, much stronger. If you plan on making some power I would go with a Centerforce dual friction.
Old Sep 17, 2002 | 02:30 AM
fauxrs's Avatar
fauxrs
Like the other poster said - more splines = more strength
Old Sep 17, 2002 | 09:35 AM
Turbo-Jet's Avatar
Turbo-Jet
Yeah, more smaller splines are stronger providing the material is the same. Analogous to fine/coarse thread fasteners in tension, as fine is stronger due to greater tensile area and smaller stress concentrations.
Old Sep 17, 2002 | 10:35 AM
norvalwilhelm's Avatar
norvalwilhelm
The 10 spline is ford and the 26 spline is chevy. If I had my choice like the others I would use the 26 spline. It is stronger.
Old Sep 17, 2002 | 11:10 AM
flood's Avatar
flood
Default Re: dumb question about splines (norvalwilhelm)
When I was looking at clutch options for my 75 they had both listed as well. A 10 and 26. Will either of these work? :confused:
Old Sep 17, 2002 | 11:19 AM
Fevre's Avatar
Fevre
Default Re: dumb question about splines (flood)
Your tranny probably has 26 spline so you have to use a 26 spline clutch. The input shaft on the tranny dictates which number of splines to use.
fauxrs's Avatar
fauxrs
The 10 spline transmissions were used behing L-48's and the 26 behind the L-82. The 26 spline has a higher torque capacity but yes GM had both in their lineup.
Old Sep 22, 2002 | 12:38 AM
LT1driver's Avatar
LT1driver
Default Re: dumb question about splines (Turbo-Jet)
more splines way to go, greater strength. :cheers:
To dumb question about splines
