Crate engine brand recommendation?
ideally around 400hp with a roller cam on a 383 small block.
Blueprint's BP38313CTC1 seems to tick all the boxes but wanted advice on other brands that might be worth considering.
Thanks!
That should have outstanding manners and make great torque everywhere. Note it is externally balanced when selecting FW/flexplate etc.
read the fine print of their warranty regarding "installs". Important
Doesnt pay to build motors anymore although really enjoyed it to try and do it for profit forget it.
Personally a little squeamish about some parts sources but if its survived the dyno and been tuned oughta be Ok.
Besides I dont believe gm sells Gen1 and 2 bare blocks anymore? Thier aluminum blocks? always lusted after one of those.
What a shame, still a good market for them. They should start mfg their good FT lifters they used to have too. Think I paid 5-600 for a new GM block back in the late 90s, hecho in mexico. It actually measured out pretty good. If they did a 400 with stronger mains and a change or two they could sell a bazillion of them. Not everyone wants China cast stuff.
Some stuff checks out Ok out outside hardness but past that pure junk found that out the hard way with some imposter "Manley" pushrods yrs ago. Hardness ck was Ok put them in a vise, with just the slightest amount of pressure they bent or snapped. Metal inside just crumbled like a dirt clod couldnt believe it. Got the real ones in there now
Thanks, P.A.W.
Thanks for the tip, will take a look at them!
The harmonic balancer that we recommend for our BP38313CTC1 is a 400 ci weighted, 8" diameter. Part number BPP400
What flexplate / flywheel should I use for my 383?
The flexplate / flywheel that we recommend for our BP38313CTC1 is a late 350 Weighted (1 pc Rear Main Seal, Externally balanced)
Recommended Stall Converter: 2000 to 2400 RPM.
Need more just take the grinder to the heads, rockers, massage the intake and youre set!
Dyno chart that shipped with the engine.
