Driveshaft u joints
Old Nov 11, 2016 | 09:14 AM
qtrmile2's Avatar
qtrmile2
Default Driveshaft u joints
Can someone give me a part number for my drive shaft u- joints for my 1970 LT1. I would like to get them from an auto parts store. I tried yesterday and they were no help.
Old Nov 11, 2016 | 10:19 AM
MelWff's Avatar
MelWff
manual transmission uses a 1310 series driveshaft u-joint. You dont mention whether you want greaseable or solid? Assuming you want solid the Moog number is 269.
Old Nov 11, 2016 | 03:10 PM
qtrmile2's Avatar
qtrmile2
Default u joints
Thanks for your reply.
Old Nov 11, 2016 | 06:56 PM
DUB's Avatar
DUB
It would be WISE to not use U-joints with a grease fitting in them....but that is my opinion on this.... which has been previous discussed on another thread.
I use only solid SPICER U-joints at my shop.
DUB
Old Nov 12, 2016 | 07:20 AM
Sluefoot's Avatar
Sluefoot
Originally Posted by DUB
It would be WISE to not use U-joints with a grease fitting in them DUB
completely....I specified AND ordered ONLY Spicer U Joints without grease fittings!! Used 'em everywhere....drive shaft AND half shafts!!!
Old Nov 12, 2016 | 10:19 AM
BlackC3vette's Avatar
BlackC3vette
I also prefer the Spicer U joint brand without the grease fitting. But, you may have to look around for them, not everybody stocks them. For my half-shafts, I actually took them to a local driveshaft shop and they also re-balanced them for me. Regardless, I believe Moog is still a good name out there.
Old Nov 12, 2016 | 11:05 AM
CanadaGrant's Avatar
CanadaGrant
Would anyone have a chart for years,trans types etc. with the Moog and Spicer part numbers for all the half shaft/driveshaft combinations?
Old Nov 12, 2016 | 02:12 PM
lvmyvt76's Avatar
lvmyvt76
the parts shop could not find the part numbers??? try a better parts shop!!!!
Old Nov 12, 2016 | 05:33 PM
DUB's Avatar
DUB
SPICER would know...and also I would have to assume the tech line at MOOG would also. I am sure if you contact them they can send you an e-mail with the part numbers and also possible measurements.
I know the truck company I get my SPICER's through has the chart. But I dio not need the chart due to stiocking all possible U-joints that can go on a Corvette. I just go in my parts room and match them up.
DUB
Old Nov 12, 2016 | 05:45 PM
jb78L-82's Avatar
jb78L-82
I'm probably going to have to have my TA arms rebuilt this winter and will be replacing the half shaft ujoints and drive shaft u joint. I have 2 questions:
1. Moog and Spicer clearly state that their greaseable ujoints are a superior design now since the grease fitting is in one of the ujoints caps and NOT in the ujoint body which does not compromise the unjoint strength. Truth?
2. Rock auto lists the Moog Non greaseable ujoints for about $15. Spicer on the site shows $75 apiece for the Spicer Greaseable half shaft ujoints. Is that price possible? Seems really high?
Old Nov 12, 2016 | 06:13 PM
DUB's Avatar
DUB
OK..I have NOT done specific testing to confirm it. BUT..regardless where the grease fitting is located. The U-join is still cross-drilled hollow so the grease can get to all the caps.
AS I have written. I have had solid SPICER U-joints last for well over 50K. In some cases 70K miles.
I prefer NOT to use U-joints that have grease fitting in them and WILL NOT use U-joints with grease fitting in them...but use what you want.
That price of $75 for ONE SPICER does seem a bit high and may not be right.
I will have to call tomorrow and see what the SPICERS are going for and get back to you.
DUB
Old Nov 12, 2016 | 06:16 PM
jb78L-82's Avatar
jb78L-82
DUB
Thanks DUB!
Thoughts on the grease fitting in the ujoint cap for both Moog and Spicer?
Old Nov 12, 2016 | 06:25 PM
DUB's Avatar
DUB
Thanks DUB!
I do not use U-joints with a grease fitting...regardless if they are in the cap or body of the U-joint. SOLID SPICER U-joints is/are what I use.
DUB
Old Nov 12, 2016 | 07:19 PM
lvmyvt76's Avatar
lvmyvt76
Old Nov 13, 2016 | 08:04 AM
tyrant's Avatar
tyrant
Got my Spicers from Amazon. Really can't beat the price.
https://www.amazon.com/gp/aw/d/B009X1X91O/ref=mp_s_a_1_1?ie=UTF8&qid=1479042109&sr =8-1&pi=AC_SX236_SY340_QL65&keywords=spicer +5-785x
Old Nov 13, 2016 | 08:45 AM
Mooser's Avatar
Mooser
Dennys Driveshaft lists the 5-1330X at $17.50 and the 5-1350X for $21.50
Not sure what Rock auto is listing there but I'd say it's either a KIT of all six of the U-joints or a mistake
M
Old Nov 13, 2016 | 09:19 AM
jb78L-82's Avatar
jb78L-82
M
Looks like rockauto lists 1330 and 1350, greaseable joints though, no 1310. I assume that the half shafts on my 78 4 speed are 1330's as well as the driveshafts?
DANA HOLDING CORP 513301X Spicer Info
Rear Shaft Front and Rear Joints; Premium Greasable
Previous Image
Next Image
$24.89
DANA HOLDING CORP 513501X Spicer Info
FitsRear Axle Shaft - Left Inner; Premium Greasable
OrRear Axle Shaft - Left Outer; Premium Greasable
OrRear Axle Shaft - Right Inner; Premium Greasable
OrRear Axle Shaft - Right Outer; Premium Greasable
Previous Image
Next Image
$74.79
For maximum strength, 1330's for the driveshaft and 1350's for the half shafts?
To Driveshaft u joints
Old Nov 13, 2016 | 11:14 AM
Mooser's Avatar
Mooser
Always best to actually check (measure cap dia and distance across the two caps) on the driveshaft in case Bubba was in there and did something extra weird.
The 1/2 shafts should be 1350s, that number you have 5-1350-1X is listed as a KIT by spicer but really seems to be only a single U-joint, greaseable with the zirc in the cap, and yes they are 3 or 4 times the price
The drive shaft SHOULD be 1330s but if someone changed anything it might be 1310 or a combination of 1330 and 1310s, measure them to be sure
M
Old Nov 13, 2016 | 11:21 AM
Mooser's Avatar
Mooser
I think this was posted by Mike (Tracdogg) a while back, I saved it and it's quite handy
http://www.driveshaftspecialist.com/...D%20Guide.html
M
Old Nov 13, 2016 | 05:30 PM
Sluefoot's Avatar
Sluefoot
I got my SPICER NON-grease zerk U-joints from www.drivetrainamerica.com
Had 'em in stock.
