Torque Specs
Old Nov 11, 2016 | 01:10 PM
Oldguard 7's Avatar
Oldguard 7
Default Torque Specs
Hello all. When torqueing a bolt to a specification, it is said it should be done in three stages. For example if a torque spec for a bolt is 80 lbs/ft. Which stages are the proper way to torque a bolt to proper specs?
Increase torque until you reach 80 lbs/ft: 10, 20, 50=80
Increase torque with 80 as the final stage: 20, 40, 80
Old Nov 11, 2016 | 01:58 PM
MelWff's Avatar
MelWff
If it was me I would go 40, 60, 80. On a 80 pound goal I think the 10 and 20 are pointless.
Old Nov 11, 2016 | 02:11 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Loaded question as it depends on whether or not you are torqueing a single bolt by itself...for which one pull to maximum is all that is required....or if you are torqueing multiple related fasteners that have a pattern to torque them in a sequence.....like a cylinder head.
On a head......torque to 1/2 the spec., run the pattern....then go around again to 100% of spec.
There is no advantage to torqueing a bolt to a partial specification....then going back and increasing it......
Torqueing in steps is done to keep the mating surfaces from warping during clamping......
For example.....the oil pump fastener bolt.....torque to 100% of specification.
Jebby
Old Nov 11, 2016 | 05:09 PM
revitup's Avatar
revitup
More importantly, are you adjusting the applied torque to account for any lube on the bolt? Most of these stated torques are for a dry bolt, unless otherwise specified. Oil or anti-seize lube can result in a 15 - 25% increase in the resulting torque load.
Old Nov 11, 2016 | 06:54 PM
DUB's Avatar
DUB
IF you apply an oil or anti-seize to the threads of a bolt or nut. The torque value should be adjusted accordingly. And this will this mean that it will take LESS torque.
DUB
Old Nov 11, 2016 | 08:18 PM
7T1vette's Avatar
7T1vette
"Staging" bolt torque is only required when a number of bolts are working together to perform some group function....as with an oil pan, a cylinder head, or a water pump installation. If you install each bolt on a stamped-steel oil pan [with 'soft' gasket] separately and at full torque, the pan rail will be so deformed that there is no way it can seal. Likewise, if you do not properly sequence the bolt installation on a cylinder head, you could increase the likelihood that the head gasket will not seal properly.
In these cases, proper sequencing and/or applying the bolt torque in stages are beneficial to the consistency of bolt clamping loads over the entire clamping 'system' those bolts provide as a set. So, it is important to consider the bolt torque "strategy" to be applied when installing bolt groupings.
Where necessary, the GM Service Manuals call out these special needs. So, it is important to research how such installations should be performed, rather than just 'gun the suckers' in with your impact tools.
Old Feb 4, 2020 | 12:00 PM
Desert Nomad's Avatar
Desert Nomad
This is correct. Only time to apply lube is if its specified. Now I do apply a bit of anti-seize to the face of a lug nut but not to the threads themselves. Doing so could over torque or even snap of the lug stud it self.
Old Feb 5, 2020 | 08:09 AM
Elcransonator's Avatar
Elcransonator
Interesting thread. I recently rebuilt an engine in my garage and there are several areas where the manual calls for loctite on the threads. I wonder if the specified torque setting has that fact "cooked" into the torque value given? Wonder if there is a formula for reducing torque setting when using anti-seize also? Anti-seize is an absolute must around here (east coast of Florida/ask me how I know that lol).
Old Feb 5, 2020 | 06:19 PM
7T1vette's Avatar
7T1vette
This is an old thread.... BUT the last post deserves an answer--just because.......
Anti-seize compound [I always thought it was " i before e, except after c " ???] should be considered a lubricant in this instance. Most torque specs in GM manuals are specified as "dry" specs, unless otherwise noted. As a general 'rule of thumb', you should reduce specified torque by about 30%, if a "dry spec" fastener is lubricated. For items like exhaust manifold bolts, you might be able to find specific recommendations for proper torque when anti-seize is used. Google can be your friend....
Old Feb 5, 2020 | 06:24 PM
derekderek's Avatar
derekderek
Also if you are googling a thread size for torque spec you must account for whether the female thread is aluminum, cast iron or steel.
To Torque Specs
