MAGIC CLEANER NEEDED!!!
Old Sep 17, 2002 | 08:41 PM
C3at16's Avatar
C3at16
Default MAGIC CLEANER NEEDED!!!
I'm in the process of cleaning up the engine of my car by hand. I'm supposed to be entering my first show on Oct. 26 but I've reallized that my engine is lightyears away from show quality...I was wondering if anyone out there had found a compond or anything that will help me move along faster and maybe help me meet the deadline. Any help would be appriciated. I believe the stuff I'm using right now is called blue magic. I'm thinking, I should try to get something else that works better. Thanks for any and all help.
Old Sep 17, 2002 | 08:51 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: MAGIC CLEANER NEEDED!!! (C3at16)
simply green seems to be a favorite.
Myself I go to the carwash just cover the carb and ignition and blast away the dirt. :D
Old Sep 17, 2002 | 08:52 PM
Steve Grodin's Avatar
Steve Grodin
I'm sure you will get opinions on favorite cleaners. Mine is Simple Green. Just be sure the engine is COLD when you spray it on.
Old Sep 18, 2002 | 12:09 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
For a heavily greased engine, I'd suggest Castrol Purple Degreaser. One BIG CAUTION! This stuff is very CAUSTIC, it contains Sodium Hydroxide which is Lye. The same stuff that is used in oven cleaner. It will foam slightly when sprayed on grease, and should not be allowed to dry on the surface, it should be washed off immeadiately with high pressure water. Wear rubber gloves when using this stuff it will eat the skin off your hands.
It will also remove paint from painted parts if left on too long, but it does work on heavily encrusted parts.
Here's some pictures of my transmission, before and after Castrol Purple and highpressure water at a car wash.
Old Sep 18, 2002 | 12:32 AM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: MAGIC CLEANER NEEDED!!! (Smokehouse69)
He's not kidding. That purple stuff ate the skin right off my arm! I had a big scab all the way down my forearm from that stuff. :bb
Old Sep 18, 2002 | 01:25 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
After removing my engine, I took mineral spirits to the engine bay. I used a nylon brush and a jar full of mineral spirits. It worked wonders, and I only used a few quarts.
Simple green is also very good.
Old Sep 18, 2002 | 01:38 AM
kingdavidrules's Avatar
kingdavidrules
gunk`s engine bright worked pretty well for me , i think the key is the high pressure wash . :hat
Old Sep 18, 2002 | 02:06 AM
Jons79's Avatar
Jons79
Just a quick note on simple green....I was in US Coast Guard and we were given drums of the stuff to use on various cleaning tasks around the boats, etc, as a test bed for the product. The stuff is amazing and does a great job on grease and general build up of crud. We lived by the stuff, not to mention it is completely toxic and safe....I have even seen a buddy of mine take his goldfish out of the tank and put it in a bottle of the stuff...keep it there awhile and put it back into the tank an hour later just to prove the point on how safe it is.
Old Sep 18, 2002 | 02:19 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: MAGIC CLEANER NEEDED!!! (Jons79)
Easy Off Oven Cleaner will do wonders too :cheers:
Old Sep 18, 2002 | 05:23 AM
tersian's Avatar
tersian
Huh? Heh...
Anyway, I dunno about the Coast Guard but USAF/Army quit using the stuff because it has been proven to be corrosive to aircraft aluminum.
http://safety.army.mil/pages/lessons...plegreens.html
Everything is corrosive :)
To MAGIC CLEANER NEEDED!!!
