71 factory alarm question
Old Nov 14, 2016 | 02:37 PM
Vettesic's Avatar
Vettesic
Default 71 factory alarm question
In the process of trying to get the factory alarm system working. Door pins and hood pin are in place. Untested as of yet. Horn under rear d/s fender there. Untested too. Relay and flasher in rear storage area cleaned and connected. My question is related to the rear key switch. The switch is gone. Can I test the system by simply connecting the wires that went to the switch together? (Door or hood open to ground the system). I believe only the horn should sound. Any info would help.
Old Nov 14, 2016 | 02:55 PM
Alan 71's Avatar
Alan 71
Hi V,
Yes you can make the 'armed' connection at the switch manually.
Regards,
Alan
Old Nov 14, 2016 | 06:18 PM
DUB's Avatar
DUB
Originally Posted by Alan 71
Hi V,
Regards,
Alan
X2.
And you asked for 'any info'. I will add this. You are aware that even if you get the system to work and you arm it. IF it goes off...it will continue to sound the horn until it drains your battery. Just to let you know...this system is rather 'prehistoric'...compared to current alarm systems. All it does is make noise.
DUB
Old Nov 14, 2016 | 07:04 PM
Vettesic's Avatar
Vettesic
Originally Posted by DUB
X2.
DUB
No I was not aware of that little fun fact. That sounds scary. Isn't that what key switch is for....to shut down system by interrupting power?
Old Nov 14, 2016 | 07:07 PM
DUB's Avatar
DUB
YES...the key switch will kill the power to the alarm system...so thus...the horn can not sound.
But if you have the system armed...and leave the car alone and are away from it....do not be surprised if you come back to a dead battery. I have had custoemr who woke up and found their car alarm was sounding off in the garage or in the drive way..
DUB
Old Nov 14, 2016 | 08:13 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Sadly, in the old days people would just take an ice pick and run it up through the floor board and into the battery... this would drain the acid and then they'd steal your car.
Here is a readable schematic for the alarm system.. While it says 1975 it's the same for your car.
To 71 factory alarm question
