70 Changing drivers side dash speaker?
They are confirmed bad.
The inside trim has to come off around the windshield....You have to take the brace off the steering wheel where the headlight override switch is located....The drivers dash gauge cluster has to be unscrewed from the top dash the center cluster gauge has to be taken loose...There is a screw that holds the top dash in place that has to come loose....
Then you can get to the screws that hold the speaker in place....Getting everything including the speaker is the hard part....I used some thin plastic washers to hold the screws to the speaker frame to make it easier on install....I saw no way to hold everything in place and the line the screws up.
I took some pics and described some of the process on my blog....Link below....Scroll down for the install.
Radio and speaker install....
Good luck....
Brian
You might try removing the 2 bolts that support the steering column below the dash, and the 2 bolts at the firewall. This allows the column to drop down about 3". (Support the column at that point so the weight of the column/wheel isn't on the rag joint.).
Remove the 7 screws that hold the lower dash in place.
Loosen the hood release bracket.
This allows the pad to droop down and be tipped slightly toward the rear and give you the access shown here.
It's just A BIT easier than removing the dash pad entirely.
Still not a pleasant job.
Good Luck!
Regards,
Alan
