Best method to install studs in the trailing arm....?
Old Nov 30, 2016 | 06:04 AM
Wee's Avatar
Wee
Default Best method to install studs in the trailing arm....?
I do not have a press....I was thinking about getting them started by tapping them in and then stacking up flat washers and using an impact on the nut and pulling them the rest of the way in....Kind of like how the bearing install works. I would rather not use any heat because I don't want to ruin the new paint.
Brian
Old Nov 30, 2016 | 08:05 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Back when I didn't have a press I did what you describe. Put grease in between the washers to allow the one touching the nut to spin. It works, but I don't like it. There were several times I stretched a stud and/or broke one. I got a Harbor Freight press for around $100 and it has more than paid for itself in other jobs.
Old Nov 30, 2016 | 08:32 AM
lvmyvt76's Avatar
lvmyvt76
take it to a machinery shop and have the work performed, try to be able to watch so it is done correctly.
Old Nov 30, 2016 | 11:02 AM
jim-81's Avatar
jim-81
I would think you would be able to pound them in.
Old Nov 30, 2016 | 04:01 PM
ignatz's Avatar
ignatz
Best method? Or easiest method? Is the axle out? If it is, best is to take it to a machine shop otherwise it will just be awkward. Easiest is to pound them in a bit to reassemble the trailing arm and then use the method you described to finish them off with a torque wrench, not an impact air wrench.
Old Nov 30, 2016 | 06:54 PM
DUB's Avatar
DUB
Beating them in is out of the question....just my opinon on that.
Possibly try this.
I generally am not a fan of using the threads to pull the wheel stud in.
I have a tool that looks a lot like the lock plate suppressor tool for a GM steering column...but it is a bit stouter. My tool allows me to pull the stud through and not stress the threads due to the nut is not spinning on it.
https://www.summitracing.com/parts/o...FUc6gQodFkcHcg
DUB
Old Nov 30, 2016 | 09:50 PM
Wee's Avatar
Wee
Thanks for all the ideas....DUB I didn't really think about the stress on the threads....I'll use 2 deepwell sockets, coupling nut and another bolt with washer to pull them on. I'll post some pics and maybe even a video if it works.
Brian
Old Dec 1, 2016 | 06:06 PM
DUB's Avatar
DUB
Brian
Brian,
I know the wheel stud will go in....because before I got my tool....I could do it. So I am sure you can get it to seat.
But something in the back of my head .....a long time ago....said to look in a factory service manual and a photo shows the tool that is used to do this. SO...feeling like I was doing my customers an injustice and opening myself up for a premature failure where I would have to go and do it all over again. So I got the tool.
DUB
Old Dec 13, 2016 | 08:44 PM
Wee's Avatar
Wee
Well my idea worked like a charm....I did freeze the studs for a few days....I didn't heat the trailing arm. They pulled on pretty easy.
Brian
Old Dec 13, 2016 | 11:24 PM
hugie82's Avatar
hugie82
Harbor Freight is your friend on jobs like this. Even the cheap ball joint tool can get the job done or a vise and a deep socket if it's off the car.
Old Dec 14, 2016 | 06:08 AM
BOOT77's Avatar
BOOT77
The coupling nut and washers/spacer would of been fine. If you really wanted to see how hard it was on the threads/bolt use a torque wrench and see if it takes more than the bolt size & grade calls for to pull it.
Old Dec 14, 2016 | 12:04 PM
Wee's Avatar
Wee
This method might be overkill but it worked well and was cheap. I was surprised how easy they pulled on....My impact is only a 12 volt.
Brian
To Best method to install studs in the trailing arm....?
