Comp Cams cant seem to answer this question so I thought I would post it here.... My cam card hot lash values are based on 1.5 rockers. I have 1.7 rockers. Should the lash values be adjusted for the 1.7 ratio?
...My cam card hot lash values are based on 1.5 rockers. I have 1.7 rockers. Should the lash values be adjusted for the 1.7 ratio?
Interesting question, and I have no idea. However, if I had this issue, and couldn't find anyone who appeared knowledgeable to provide an opinion, I'd say no, but I've never really considered the need for valve lash to begin with. Clearly, and most basic, it ensures that the valves actually close. If part of the reason to have them close is to help them pass off their heatload, then it might suggest that the valve lash would need to be increased with the new rockers.
Lash should indeed change according to rocker ratio.
You want the lash point to be at the end of the lash ramp on the cam lobe.... A higher ratio rocker arm opens the valve... or in this case closes up the lash faster/sooner, so in the case of replacing 1.5 rockers with 1.7 rockers you need to increase lash to make this happen.
Mike Jones of Jones Cams and Dick Jones of Controlled Induction explain the formula to determine how much lash should change based on rocker ratio and the parameters involved in how/why you should adjust valve lash values based on rocker ratio in this thread.
Thanks! I thought I read that somewhere and indeed opened my lash up proportional to the increase in ratio. Basically divided the lash by 1.5 then multiplied by 1.7. Now that you mention it I think the yellowbullet is where I read it. I will check out the link to make sure I got it right. From what I understand by not increasing the lash, you are adding duration to the cam. I have plenty of duration so I don't want or need to do that. The down side is harder on valve train and more noisy.
Yes it needs to change. Take your hot lash and divide by 1.5. That number is the clearance lash for the ramp. Now take that number and x by 1.7 and that will be your lash based on you using 1.7 rockers.
I went to the struabtech site and they appear to be a little over $900. Which is in line with all of these high end solid roller lifters. If I have a problem with either of my present two sets from another vendor I'm going to buy them.
I think Chris said on another forum those lifters are $1300.00. I bought a set of the Morel bushed solids from Chris a couple months ago. If these had been out then, probably would have gone with these. Looks promising.
They are just under the above number. Availability is now. Will have at PRI show.
