Engine temp and Heater
Old Dec 21, 2016 | 02:02 PM
  #41
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Originally Posted by Robert.L.Harris
Ok, I pulled out the console. The Selector Switch for Off/AC/Def/Heater is electrical, not a mechanical cable like my Jeep. The mechanics appear to be working right. Now to track down where the far ends come out and check for power at those connections.
If you don't already, please get a hand held vacuum pump. You will be able to test 100% of the system for door movement without the engine running.
Old Dec 24, 2016 | 10:37 AM
  #42
Robert.L.Harris's Avatar
Robert.L.Harris
I still haven't had a chance to check coolant/heat flow, but I did find out the fuse that powers the selector switch is blown. No, not in the fuse box. Under the center console someone took the cigarette lighter, AC/Heat selector and something else and wired together. Oh yes, they used a bunch of fuses including a single 30A that all 3 wires go into and if I use the cigarette lighter ( USB Phone charger ) and the AC, it blows the fuse. So I have to find the wiring diagram somewhere to find out which of the cut wires under the center console should actually be going to which connection.
Anyone have a wiring diagram that's easily read/seen? I found an assembly manual which looks great but it doesn't give wiring colors, just "plug connector A6 into X"...
Old Dec 24, 2016 | 10:46 AM
  #43
Big2Bird's Avatar
Big2Bird
Lectric Limited has good diagrams. Service manual should as well, at least 81 does.
If the fuse is blown, the fan may be kaput.
One last thing. If you get it all working, and its still cold, pull the heater blower and look for leaves/critters.
Old Dec 24, 2016 | 11:50 AM
  #44
Robert.L.Harris
Looks like they have some great parts but I'm not seeing manuals for a '79.
Old Dec 24, 2016 | 12:03 PM
  #45
Robert.L.Harris
Just found this thread:
http://www.c3vr.com/vrforums/c3-elec...agrams/236625/
The link in the first post is ver worth a quick browse for anyone looking for C3 wiring diagrams : https://sites.google.com/a/c3vrmail....iring-diagrams
Old Dec 24, 2016 | 12:04 PM
  #46
Big2Bird's Avatar
Big2Bird
Lectric Limited has laminated charts.
For service manuals, a certain online auction site works well.
