Chasing an idle
I recently went through this on '67 427 tri-power. The supposed rebuilt distributor with electronic ignition actually had the wrong springs in it and it would not get down below
1200 rpm's and would die. When the original distributor was installed...it ran fine and a
curb idle could be set.
DUB[/QUOTE
It often times is so hard to diagnose problems when 'we' are not there to see what is going on.
So...personally I would address the idle RPM issue and then see what goes on with the temp issue if that is even an issue after the idle has been corrected.
I am curious on how well it idles BEFORE the temp gets high enough to open the thermostat...because it should be able to achieve 'curb idle' BEFORE the temp reaches the point where the thermostat opens.
If the coolant temp is not to the point of boiling over (or overheating...which it appears it is not the case)...I am not taking any dynamics of the cooling system into consideration at this point.
DUB
I sgree this is an advance spring issue as mentioned. I will look into that however it has been below 10* here. So it will wait a bit.
For other thoughts on cooling system; it has nothing to do with the curb idle. I don't have a problem with the fans or shroud. All is in tact and all is new. The engine does not overheat and I have ran it in stop and go traffic when it's been 100*_105• with no problems. There is no sensor that controls anything.
When temp comes up to operating it holds the idle on its own. When temp is cool or cold and the chock comes off the high idle it needs a little gas feed to stay running until the temp comes up. I think this is very normal for any carb engine if the choke is not adjusted correctly or as suggested the advance springs are too weak.
Its not the trans cooler. The oversized cooler is more than adiquate. Not a part of the problem.
Plrsse re read what I first posted and re read what Dub provided above.
I think it's my solution. I also know that with a big cam fed on a carb it's never going to be perfect at low temps. I just like things perfect.
I assume it is an electric choke???
Because if in a few more minutes of running...you do not need to 'feather' the gas pedal...then it just might be a bit touchy because it has not warmed up enough... or a very slight adjustment on the choke.
Due to you have a stouter cam...like I tell some customers with them. You can not expect it to be the same as a street cam. Sometimes they may require a bit more warm up period....and if the engine runs great when it has bit more time to get hot....then live with it. Like I tell them...me trying to get their engine to run PERFECTLY through the warm up stage ....when I am trying to get it 'just right' within a minute or two period of time when it is warming up is pointless....because that moment in time will soon no longer be an issue due to the engine is now hotter.
I worry about start up and fast idle...and how it runs when it is at operating temperature. Any temperature that falls between cold start up and operating temperature is pointless for me to spend time on.
DUB
DUB
The best way to check the vacuum advance would be using a Mityvac and finding how much vacuum is required to fully move the advance. Then, use a gauge on the engine and make sure the engine vacuum is at least 2in-Hg more vacuum. without the right equipment, at least plug it in and make sure it stays fully advanced in and out of drive, even if you lower the idle below the normal idle rpm.
The reasoning is that idle rpm will somewhat follow the advance. So, if the advance drops as the rpm drops then that cause the rpm to drop even further. It's basically a feedback loop that works against having a stable rpm.
Many EFI systems will move the timing opposite of what the idle rpm is doing to try and stabilize the idle. So, if the idle rpm drops a bit the system will add some advance to correct the rpm.
I worked on a big block that was finicky...once it got to correct operating temp....it would be able to peel your eye lids back. If it was not at correct temp...it...as I wrote...was finicky.
DUB
