Check Your Bolts
Old Dec 20, 2016 | 11:33 AM
Cavu2u's Avatar
Cavu2u
Default Check Your Bolts
I went to tighten down a leaking Valve Cover this morning, and I noticed a wavy Lock Washer on an Exhaust Manifold Bolt wavin'! (circled) It didn't have more than a pound or two torqued on it. Went to check the other manifold bolts (both heads) and, sho nuff, each one took a quarter to a half turn to tightened. Aluminum Cylinder Head. About 10K miles since last tightened.
Steve
Old Dec 20, 2016 | 12:50 PM
Revi's Avatar
Revi
Old Dec 20, 2016 | 01:05 PM
Alan 71's Avatar
Alan 71
Hi Steve,
This is probably better than being reminded to 'check your nuts'.
As Revi posted, originally 'french locks' were used.
But, only on the 2 end pairs of bolts, not at the center pair on each manifold.
The french locks go on the bolts first…. before the washers or radio shielding support brackets.
Regards,
Alan
The original french locks had round tabs, not the square tabs as the the replacements typically have. Thus the round tab locks are highly sought after by a few people.
Old Dec 20, 2016 | 01:14 PM
c3_dk's Avatar
c3_dk
I think it is time for a re-check !!!
Thanks for the heads up........
Old Dec 20, 2016 | 09:59 PM
Cavu2u's Avatar
Cavu2u
Originally Posted by Alan 71
Hi Steve,
Amen Brother.
Yes, lock plates. I remember them on the Half Shafts, but wasn't aware they were used on the Exhaust Manifold Bolts. A perfect application.
Thanks Revi and Alan!
Steve
Old Dec 21, 2016 | 09:15 AM
Blue73Shark's Avatar
Blue73Shark
Thanks Steve. Good way to spend an upcoming warm day.
Fran
To Check Your Bolts
