Th350c torque converter relay
Old Dec 24, 2016 | 05:50 PM
Danny.reamer's Avatar
Danny.reamer
Default Th350c torque converter relay
Can someone please tell me where the relay is for the th350c. I am thinking its staying locked up all the time. So instead jacking up the car and throng to find where the wires go into the transmission I was hoping there was a place under the hood to just unhook it and test it out
Old Dec 24, 2016 | 06:24 PM
Big2Bird's Avatar
Big2Bird
Under the hood , where the wires come from the dash, under the relay rack up high are 3 connectors.
1)A one pin packard style plug that you disconnect to set timing.
2)A 4 pin weatherpak plug that goes to the dizzy.
3)A 3 pin weatherpak plug that runs down to the tranny. Unplug that 3 pin jack marked ABC
Old Dec 24, 2016 | 06:43 PM
diehrd's Avatar
diehrd
What year ? on my 1980 it used a vac/elec switch along side the break booster . 81 my be different .
Old Dec 24, 2016 | 06:48 PM
Big2Bird's Avatar
Big2Bird
81 operates off the ECM, so yes, 80 is different. I forgot to ask what year.
Old Dec 24, 2016 | 08:17 PM
Danny.reamer
I have a 81 I was wondering if this is what I'm looking for it's next to the brake booster by the fire wall
Old Dec 24, 2016 | 08:21 PM
Big2Bird's Avatar
Big2Bird
Nope.
Just inboard of that are 3 connectors just going wiring to wiring. Take that picture and post.
(Between that relay and the dizzy, just loose and hanging there).
Old Dec 26, 2016 | 12:30 PM
fishslayer143's Avatar
fishslayer143
Your TCC cannot stay locked all the time.. the engine would die when you stop ..It should only be engaged while trans is in high gear ,, watch your tach, you can see it lock and unlock by 200-300 rpm change at steady throttle in high gear at 40-45 mph
Old Dec 26, 2016 | 01:10 PM
7T1vette's Avatar
7T1vette
There could be a computer malfunction, a wiring fault, etc. So "things" can happen that you don't expect. Whether an 80 or an 81, there should be a relay that is fired by the L/U circuit or the ECM. If that relay has failed in the 'closed' position, it would cause a problem.
It is possible that the ECM actuates the L/U clutch directly, but it would be unusual for a computer to pass significant current that way.
I don't have an 80 or 81, so I don't own the documentation for directly answering your question.
Old Dec 26, 2016 | 01:19 PM
Big2Bird's Avatar
Big2Bird
There is a relay, however, it also operates the EGR bleed solenoid. So, I was trying to direct him to the tranny harness.
Old Dec 26, 2016 | 09:24 PM
Danny.reamer
Thanks for all the input. Big2bird I found the wires you were referring to and got them unplugged and that seemed to fix it for the most part. It actually broke the wheels loose for the first time and didn't seem to be sluggish like it always has lol. Now I just need to figure out w it won't shift manually. I can put it in drive and it will go through all the gears but if I put it down to first I pulls good when I shift to second the doesn't do anything but slip then when I shift to third it chirps the tires nicely. Idk
Old Dec 26, 2016 | 09:29 PM
Big2Bird's Avatar
Big2Bird
Its rebuild time.
If your going to do that, I suggest upgrading to a 700R. It will cost you double the rebuild or more, but it's a great upgrade.
My 2 cents.
Old Dec 26, 2016 | 09:34 PM
Danny.reamer
Originally Posted by Big2Bird
Its rebuild time.
My 2 cents.
Maybe so I'm no transmission gut but it just doesn't make any sense why it works perfectly n drive (3rd) but not manually. Why the 700? I was wanting to swap to a 200r if I have to do that because of the more direct fit but is there and better advantages to the 700?
Old Dec 26, 2016 | 09:45 PM
Big2Bird's Avatar
Big2Bird
They both have good points and bad points. Do some searching.
I used a later model case, many upgraded new parts, and a hydraulic lock up kit in mine.
Bow-tie cross member, and shortened the driveshaft. Added the shiftworks shifter kit.
350C was not a very good tranny.
Old Dec 26, 2016 | 09:54 PM
'75's Avatar
'75
You should be able to unplug the connector from the side of the trans and drive it, if it doesn't go into lock up then the tcc solenoid is ok, it can fail. Not sure about the 350C, but the 2004r can get the tcc solenoid stuck and the converter will stay locked in all gears except 1st.
Old Dec 26, 2016 | 11:31 PM
7T1vette's Avatar
7T1vette
Lockup cannot function in low range (by design). That's why an "always ON" L/U will not kill an engine when car comes to a dead stop.
Old Dec 26, 2016 | 11:35 PM
Danny.reamer
It still makes no sense to me why it works good in automatic mode but not manually shifting
Old Dec 28, 2016 | 01:19 AM
7T1vette's Avatar
7T1vette
In the one instance (in drive), the range valve is in 'drive' position and the valve body just does it's 'thing'. In the other (manual shifting), the range valve is moving through 1st, 2nd (where it just slips), and then 3rd. So, the difference is the range valve is in a different position. Also, you are moving the shift lever, so the shift cable/linkage is in a different position: drive rather than in specific range.
You should watch the action of your shift cable as it is worked through the ranges and look to see if it is a smooth action from one range to the next (and so on) or if there is some 'stop & go' type jerking as the cable is moved. It is possible that the range valve is not positioned properly in 2nd range and no signal to that clutch is sent.
P.S. So I agree with you that the 2nd range clutch should be OK, since it operates OK in automatic shift mode.
Old Dec 28, 2016 | 01:48 AM
Danny.reamer
Thanks I'll check all that and hopefully get it figured out it has been driving me crazy
To Th350c torque converter relay
