1973 Power Window Problem
Old Dec 28, 2016 | 05:33 PM
TheJinx's Avatar
TheJinx
Default 1973 Power Window Problem
in my 1973 Corvette stingray the driver side window won't roll up (it doesn't have power. I checked my switch & it's good. & I checked the power to the switch & the power is there. I bought a new power window motor & plugged it in but that also didn't fix it. what else could my problem be?
Old Dec 28, 2016 | 05:57 PM
SwampeastMike's Avatar
SwampeastMike
I believe that '73s have a power window relay. Sorry but I'm not certain of its location.
Old Dec 28, 2016 | 06:39 PM
Peterbuilt's Avatar
Peterbuilt
It could be a bad relay (which is under the shifter console) but first make sure that the PINK=BLACK is plugged into the fuse box.
Old Dec 28, 2016 | 08:59 PM
lvmyvt76's Avatar
lvmyvt76
could be a broken wire where the wire goes into the door?
Old Dec 28, 2016 | 10:04 PM
stumpshot's Avatar
stumpshot
My $$$ would be on a broken wire at the door. I've had this same problem. Pull the accordion boot off between the door and the body and give the wires a little tug in both directions. More than likely that's the problem.
Old Dec 29, 2016 | 05:30 PM
Doug1's Avatar
Doug1
I tend to agree. I haven't had this exact problem with my c3, but I did with my c5, the connections in that plug, get loose.
I doubt the relay would only leave one door bad, but I could be wrong.
Keep your original motor if you haven't trashed it or used it as a core, not sure if there is a core charge on window motors.
Old Dec 29, 2016 | 07:05 PM
DUB's Avatar
DUB
I recently worked on one that had power to the motor but it was a really dirty connector. Once I cleaned it...the window worked. that is assuming that you have power at the connector.
DUB
Old Dec 29, 2016 | 07:32 PM
OldCarBum's Avatar
OldCarBum
I had the same issue with my '73 when I brought it home. I tried to roll down the window and nothing. I went through the system and found all the electrical circuits were good. I was about to order the new motor when I accidentally hit the switch the wrong way and found that Bubba had installed the drivers side window switch upside down. It only cost me about two hours of wasted time. Good luck.
Old Jan 2, 2017 | 12:52 AM
TheJinx's Avatar
TheJinx
Thank you for the reply! & my switches are upside down as well! haha
Old Jan 2, 2017 | 12:53 AM
TheJinx's Avatar
TheJinx
DUB
I'll definitely check my connector! Thank you!
Old Jan 2, 2017 | 12:54 AM
TheJinx's Avatar
TheJinx
I've thought about checking the door I just never got to it haha i'll definitely check that now! Thank you!
Old Jan 2, 2017 | 12:55 AM
TheJinx's Avatar
TheJinx
Possibly. Thank you!
Old Jan 3, 2017 | 10:59 PM
OldCarBum's Avatar
OldCarBum
Well, it sounds like Bubba is learning. At least on your '73 he installed them both upside down
Old Jan 4, 2017 | 09:00 AM
Cavu2u's Avatar
Cavu2u
Folks,
I'm assuming upside down means pushing the switch forward or down, the window operates UP, and pulling the switch back or up, the window operates DOWN.
There's a fix for that.
http://repairs.willcoxcorvette.com/c.../power-window/
Or, Bubba took the switch apart to clean it, and put it back together with the plug board oriented 180 degrees out.
Sorry for the hijack Jinx. Hope your fix is a simple one.
Steve
To 1973 Power Window Problem
