Lowering bolts
Old Dec 30, 2016 | 03:24 PM
Kacyc3's Avatar
Kacyc3
Default Lowering bolts
I need 10" bolts local Rural King,Fastenal, Menards, Tractor supply, OK fasterners, Superior Industrial, Ecklers all dont have the right size. Where did you get yours?
Old Dec 30, 2016 | 03:40 PM
Richard454's Avatar
Richard454
VBP
C4 bolts
https://www.vbandp.com/auto-parts/c4...96-detail.html
before-
DSCN4110 by Richard Hayes, on Flickr
After-
DSCN4137 by Richard Hayes, on Flickr
Old Dec 30, 2016 | 03:48 PM
Kacyc3's Avatar
Kacyc3
Originally Posted by Richard454
are those 9/16" or 1/2" bolts?
Old Dec 30, 2016 | 05:04 PM
MelWff's Avatar
MelWff
the standard bolt is 9/16" in diameter and should be at least grade 8
Old Dec 30, 2016 | 05:35 PM
redvetracr's Avatar
redvetracr
you might want to re-measure the shaft of a factory bolt, not the thread the shaft
Old Dec 30, 2016 | 06:17 PM
wendellp601's Avatar
wendellp601
I ordered mine from Fastenal, along with some nylon insert nuts.
Old Dec 30, 2016 | 10:19 PM
Kacyc3's Avatar
Kacyc3
They told me they cant get anything over 7.5"
Old Dec 30, 2016 | 11:16 PM
CanadaGrant's Avatar
CanadaGrant
Corvette Central has 8" bolts with nyloc nuts. I think that's a couple of inch drop from stock.
http://www.parts123.com/corvettecent...50g&ukey=26992
Old Dec 30, 2016 | 11:54 PM
Kacyc3's Avatar
Kacyc3
this is with 7" bolts
Old Dec 31, 2016 | 12:26 AM
CanadaGrant
Wow, I see what you mean.... That's some spring.
Old Dec 31, 2016 | 12:31 AM
Kacyc3's Avatar
Kacyc3
fiberglass mono no idea the rate but, tired of the 4x4 look.
Old Dec 31, 2016 | 08:19 AM
wendellp601
I ordered from the website...
I can't remember the diameter / thread pitch, but they are definitely available.
https://www.fastenal.com/products?r=...|sattr06:^8$|~
Old Dec 31, 2016 | 10:16 AM
Franks73's Avatar
Franks73
I think I got longer bolts from Ecklers, think they were used on the C4 Vettes. Beware of how close the ends get to the road, think flat tire situation. Good Luck!
Old Dec 31, 2016 | 10:33 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Yep or buy run-flats. I would not use 10" bolts for this reason. I have 8" bolts which are at the limit should my tire go flat. 10" bolts would be a disaster I would think.
Old Dec 31, 2016 | 12:01 PM
MelWff's Avatar
MelWff
Default bolt diameter
So what do you think the diameter is? See post #2 in the thread below.
https://www.corvetteforum.com/forums...bolt-size.html
Old Dec 31, 2016 | 01:29 PM
Kacyc3's Avatar
Kacyc3
I want 10 so I can get the height right, then cut off unneeded length.
Old Dec 31, 2016 | 03:56 PM
7T1vette's Avatar
7T1vette
FastenAll can special order some longer bolts, but they are rather costly. But, here's an alternative to special bolts (which the purists won't like) that is doable.
Go with the standard 9/16" bolts, but buy four of them [aprx. 5" long]. Also purchase four 9/16" thread jamb-nuts and two 9/16" full-threaded unions. Size the bolts as needed to get the ride height you want. On each side, install one bolt from the top, then install a jamb-nut and a union [engage the union least 9/16" on to the bolt]. Now, install the second bolt from the bottom and put a jamb-nut on it. You can get the equivalent of a 10" bolt with two 5" bolts connected with a union fitting with jamb-nuts to lock the bolts to the union solidly.
Once you have driven the car a while to let it all settle down, you can make minor adjustments in ride height [with the union position] to finalize the change. When satisfied with it, back off each jamb-nut and put a drop of high-strength Loctite on the threads to fix the jamb-nuts after tightening.
P.S. I don't believe the factory installed Grade 8 bolts in that location. If memory serves, they used Grade 5 fasteners there. Grade 8's are very strong but more brittle, and they will not have the 'toughness' of the Grade 5's . Just something to consider.
To Lowering bolts
Old Dec 31, 2016 | 07:17 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
How much unneeded length will you have is the question. I have 8" bolts and less than an inch unneeded and would like to lower my rear even more which would require 10" bolts. I'm playing it safer and live with the extra inch or so of ride height.
Old Dec 31, 2016 | 11:23 PM
Kacyc3's Avatar
Kacyc3
before i did that I would buy grade 8 9/16 all thread/threaded rod, cut to length and jam nut each end, if i can find it.
Old Dec 31, 2016 | 11:40 PM
'75's Avatar
'75
I'm using 1/2" grade 8 bolts, each bolt is good for over 3000 lbs of weight x 2 that's 6000 # capacity, that's nearly twice what the car weighs, there's typically 1/2 of the cars weight on the rear. Safety factor of 4, I'm not worried!
