1971 Ignition Shielding
Old Jan 4, 2017 | 01:39 PM
Vettesic's Avatar
Vettesic
Default 1971 Ignition Shielding
Shields that come off distributor cover. Either side nothing to secure too at bottom of shield. Couldn't seem to find a diagram in the assembly manual.
Old Jan 4, 2017 | 03:04 PM
Alan 71's Avatar
Alan 71
Hi V,
The shielding is shown in the AIM.
UPC 6, Sheet B6
And, in the radio option pages.
UPC U69, Sheets A5 and A6.
On the right side the vertical shield uses a wing nut to bolt to the spark plug wire guide bolted to the blocks rear flange on that side.
On the left side the vertical shield uses a wing nut to bolt to a u-nut mounted in the bottom surface of the chrome plated radio shield for the 2 rear spark plugs.
Regards,
Alan
This Keen diagram is for a later engine but shows accurately how the bottom of ech of the vertical shields is secured.
Old Jan 4, 2017 | 07:15 PM
Vettesic's Avatar
Vettesic
Originally Posted by Alan 71
Hi V,
UPC 6, Sheet B6
Regards,
Alan
I see it now in the aim. I have plug shields on the car for r side mounting. I'll crawl under car tmoro to get a better look. Not sure about l side. Thank You Alan!
To 1971 Ignition Shielding
