Power Window Motor Question.
Old Jan 18, 2017 | 11:56 AM
Bloodzone's Avatar
Bloodzone
Default Power Window Motor Question.
Will the window motor operate without being mounted in door? I have my pass door gutted working on the regulator. I plugged in the motor into its harness and she wont move when I hit the switch. I checked the wires and both are good. So either motor just quit on me or something else is going on.
Not a bad time for it to quit since its outta the car.
Old Jan 18, 2017 | 12:14 PM
Big2Bird's Avatar
Big2Bird
Did we turn the key on?
Old Jan 18, 2017 | 12:40 PM
Bloodzone's Avatar
Bloodzone
hehe, yea we did. I know it sounds crazy but It was working fine before I pulled it. I even gave it a hammer love tap like you would a starter thats going bad.
Old Jan 18, 2017 | 12:42 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It the motor housing grounded?
Jebby
Old Jan 18, 2017 | 12:51 PM
Bloodzone's Avatar
Bloodzone
It is not. Its out of car unmounted. I'm assuming its grounded by the door frame and should work when placed back in car??
Old Jan 18, 2017 | 12:57 PM
Big2Bird's Avatar
Big2Bird
Have any jumper cables?
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yes....or ground negative bat terminal to housing...
Jebby
Old Jan 18, 2017 | 01:01 PM
Bloodzone's Avatar
Bloodzone
Perfect, thanks...getting the cables out.
Old Jan 19, 2017 | 11:34 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
motor must have good solid Ground to function. (Do not assume it is grounded thru door hinge.)
after that 12 volts on either terminal to moves up or down.
I add a gnd. wire for power windows when i build them.
Old Jan 19, 2017 | 02:32 PM
7T1vette's Avatar
7T1vette
Just to be clear: The two larger leads coming from the motor are NOT 'positive' and 'negative'; they are 'positive' leads for UP and DOWN. There should be a smaller grounding wire OR the case should be grounded for battery 'negative'.
I would not suggest that you put power to the motor without restraining it somewhat. It has quite a bit of torque and the motor will 'jump' when you put power to it, if not restrained.
Old Jan 19, 2017 | 03:50 PM
Bloodzone's Avatar
Bloodzone
All done. Everthing is back together and works great. I was replacing a bad regulator gear.
Thanks for all the help. Corvette forum is best tool I got
To Power Window Motor Question.
