Vacuum question help
Old Jan 19, 2017 | 08:46 PM
CAMS69's Avatar
CAMS69
Default Vacuum question help
This is the vacuum control that is mounted to the side of the brake booster housing. I did not take a picture of its location when I took it off. (Stupid). There is another one located between the horns under the front nose on my car. I have seen two up front on some diagrams as well as one. I know for a fact in my car it only had one under the nose area. So I'm assuming this one goes on the booster area. Notice it has the mount on top. I've seen on some cars that there is an additional bracket this attaches to but I don't have it . Never saw it? Was this mounted somewhere else? 69 coupe 360 with air thanks!!!
Old Jan 19, 2017 | 09:20 PM
CAMS69's Avatar
CAMS69
Default Think I found it..,,
Looks like it is also mounted on the passenger fender. Far right in pic.
this is for an early 69 (mine) but curious it shows two under front hood. Mine only had 1. ?
Old Jan 19, 2017 | 09:23 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Pretty sure pre-70 cars only came with 1 for the headlights
Old Jan 19, 2017 | 09:49 PM
CanadaGrant's Avatar
CanadaGrant
My 69 has 2 total. One for the headlights mounted in the center between the two headlights and the washer door relay on the firewall just inboard of the brake booster. I think there was a single headlight vacuum relay until 1970 when it changed to two. Also, 1968 and early 69 had the wiper door vacuum relay by the passenger side inner fender. It was changed to the drivers side firewall mid 69 year.
Old Jan 20, 2017 | 07:41 AM
Alan 71's Avatar
Alan 71
Hi,
CG is right.
For 71 the wiper door relay location was moved back to the rear of the right side wheel apron and the headlight system continued to use 2 relays located between them mounted on a plate that was crewed to the headlight reinforcement bar.
Regards,
Alan
71… 1 wiper door relay on apron
71…. 2 headlight relays.
Old Jan 20, 2017 | 10:10 AM
CAMS69's Avatar
CAMS69
Thanks for the replies. Mines a early 69 and there is only one mounted up front between headlights. The other must go on the passenger fender well. There was no provision on mine for it to attach to my brake booster support. Thank
Old Jan 20, 2017 | 01:34 PM
CAMS69's Avatar
CAMS69
Default ahhh
found someones pic online. not my car. this must be where mine goes?
notice it right in front of the "gill" behind the spark box
Old Jan 20, 2017 | 02:28 PM
Alan 71's Avatar
Alan 71
Hi cam,
Typically there's a plate riveted to the fiberglass apron on the wheel side of the apron that has two holes that the relay mounting screws tighten in to.
This the plate and location on a 71.
Regards,
Alan
Old Jan 20, 2017 | 02:31 PM
CAMS69's Avatar
CAMS69
Originally Posted by Alan 71
Hi cam,
Regards,
Alan
Thanks alan , pretty sure i have that plate..
Beautiful car you have and thanks for your help.
You're a true asset to this site.
btw, Cam is my son (hoped he'd help with the 6 year process..but)
I'm Jef
Old Jan 20, 2017 | 03:55 PM
Alan 71's Avatar
Alan 71
Hi Jef,
Thanks!
You really can't make kids want to be interested in working on an old car… hopefully, if he's around it he'll 'join up'!
Regards,
Alan
To Vacuum question help
