Hi Steve,
Well Done!
Fabricated a tool too!!!!
Hopefully this indeed will be the last time!
(You realize that as long as you keep the tool you made you won't need to use it again!)
Regards,
Alan
Hi Steve,
Well Done!
Regards,
Alan
My front poly a-arm bushings have lasted over 10 years and 20k miles. So as others have said, good there.
Poly bushing are a bad idea on stock rear strut rods (bind and self destruction) or both ends of aftermarket ones (loosen up adjusters and/or bind). Better off with bushing on one end and spherical bearing on other end of each there or stick with stock style and rubber.
I had competiton adjustable Heim jointed strut rods for over 10 years now (with zero issues) and they are by far superior to the OEM rubber bushing struts and/or poly.
