pulling engine
Old Jan 27, 2017 | 11:07 PM
sparky77's Avatar
sparky77
Default pulling engine
I'm pulling the engine out of my 77 ,the question is I'd like to take the trans out with the engine all at the same time.I just talked to a guy at a rental shop that told me you can't, what do you guys say,has anyone done it ? Engine is a L82 and the trans is a TH400.Taking both out at the same time and reinstalling both is easier than trying to line up the trans and bolting it in.
Thanks,Pete
Old Jan 27, 2017 | 11:12 PM
Kacyc3's Avatar
Kacyc3
Thanks,Pete
I have done it on an 80 Camaro, I have not done it on my vette
Oldguard 7's Avatar
Oldguard 7
Yes it can be done both ways. Most like to pull engine and trans together. Some say it's easier. last week I tried to install my engine and had trouble getting the engine and trans to line up (see engine install nightmare thread) I reinstalled the engine this wendesday and the damn thing mated into the trans easily (didn't even take but a few minutes, go figure.
Old Jan 27, 2017 | 11:16 PM
Oldguard 7's Avatar
Oldguard 7
Yes it can be done both ways. Last week I had a hard time getting the engine and trans to line up (see engine install nightmare thread) I installed the engine Wendesday and the damn thing mated to the trans easily (go figure).
Old Jan 28, 2017 | 02:04 AM
Zorro O's Avatar
Zorro O
Pull and replace the engine and trans together. If you haven't done this on a C3 before, it's done from the side of the car. Goes back in the same way.
Old Jan 28, 2017 | 08:18 AM
sparky77's Avatar
sparky77
My engine hoist is not long enough to line up with the engine so I'm going to have to find one thats longer but there are a few gear heads that live around here.
Thanks,Pete
Old Jan 28, 2017 | 08:24 AM
havesometo's Avatar
havesometo
I pulled my engine and trans at the same time from the front of the car.
Old Jan 28, 2017 | 09:00 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
how much of a pain is realigning the hood when you re install it?
Old Jan 28, 2017 | 09:24 AM
Oldguard 7's Avatar
Oldguard 7
Some members leave the hood on the car. I always take ff the hood. Its no pain at all imo
Old Jan 28, 2017 | 09:59 AM
Revi's Avatar
Revi
Typically Ive seen engines with manual transmissions pulled as one unit, but engines with automatic transmissions were pulled separately.
Old Jan 28, 2017 | 10:00 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Before you remove the hood, make chalk marks around the mounting plate that attaches the hood to the hood support bracket. On install, just line up the chalk marks and tighten fasteners. Do this with a helper.
Old Jan 28, 2017 | 10:02 AM
havesometo's Avatar
havesometo
Originally Posted by Revi
Typically Ive seen engines with manual transmissions pulled them as one unit, but engines with automatic transmissions were pulled separately.
I pulled mine and reinstalled it with 700r4 attached to it.
Old Jan 28, 2017 | 01:28 PM
theandies's Avatar
theandies
That is the only way I've done it. Two times now. Once to remove the old truck engine it had when I bought it to install my ZZ4 and just last year when I replaced my clutch and did some other minor stuff.
Easy and I don't listen to any parts counter guy unless I know them to be gear heads. Just go to your local parts store and get a load leveler. It makes the job a lot easier.
I've always taken it out from the side as the lifts I rented didn't have the reach to go over the front clip. Either side will do.
Old Jan 28, 2017 | 03:03 PM
BKbroiler's Avatar
BKbroiler
The engine and trans can certainly be pulled together but it is more work that way, particularly with an automatic. If the trans stays in the car, its 6 bolts on the trans and 3 on the converter. You have to unbolt all that after the engine and trans are out anyway. You don't touch the driveshaft, crossmember, shifter and cooling lines if the trans stays in. And, you can leave the hood on.
Old Jan 28, 2017 | 07:29 PM
lvmyvt76's Avatar
lvmyvt76
just mark around the hinges with a pencil, and then you can alaign it up easier. I pulled the engine out by itself, pulling the transmission out first fron underneath(by myself). the engine came out easy(doing it by myself again). the car was on tall jackstands, very high, enough to roll the trans under the car while on a floor jack. this was on a 76 with a removable transmission support.
Old Jan 28, 2017 | 09:15 PM
BLUE1972's Avatar
BLUE1972
To line up the hood drill a hole in the hinge between the two bolts - (new sharp bit) 1/8 or 3/32 diameter or so. Use a stop on the drill so it only goes through the hinge and mounting plate - not the top of the hood. You can pull a bolt from the hood to see / feel how much room there is.
When you put the hood back on use 2 drill bits (same as the hole size) and put them into the hinge - the hood will align perfectly. Put black silicone in the holes. Done..
I pull the radiator support and pulled the engine and trans. No issue - again from the side. Kind of a 45 degree pull.
Old Jan 28, 2017 | 09:42 PM
7t9l82's Avatar
7t9l82
The key point is the engine crane goes in on the side of the car and not the front like on most cars as several people have said.
I never had a problem pulling the hood and normally I pull and install the engine and trans together. It's what your used to. Pulling the driveshaft, cooling lines and trans linkage really isn't a big deal. It also let's you change the transmission seals easier.but there is no right or wrong way.
To pulling engine
Old Jan 28, 2017 | 09:47 PM
havesometo's Avatar
havesometo
I don't understand why most people are insisting it has to be pulled from the side of the car. It does not have to be done that away..... if your host is long enough and you remove the hood you can pull it the front of the car.
Old Jan 28, 2017 | 09:57 PM
7t9l82's Avatar
7t9l82
Sure, if your crane is long enough., for that matter you don't need an engine crane at all just something you can hook a winch come along or block and tackle to and have at it.
Old Jan 28, 2017 | 10:02 PM
havesometo's Avatar
havesometo
You are the one insisting that has to go from the side as a matter fact this is your exact words.
