Shifter change
Old Feb 6, 2017 | 11:45 AM
Jeff k's Avatar
Jeff k
Default Shifter change
I'm considering changing from the stock shifter (4 speed) to a Hurst competition model. I am assuming that the Hurst bolts to the trans tailshaft rather than the stock cross member bracket as the factory one did. Can anyone enlighten me?
Thanks!
Old Feb 6, 2017 | 11:59 AM
MelWff's Avatar
MelWff
it does bolt to the tailshaft and below is a link to the instructions
http://files.dpbrands.com/hurst/inst...ns/3917992.pdf
Old Feb 6, 2017 | 12:09 PM
Jeff k's Avatar
Jeff k
Thanks Mel!
Old Feb 6, 2017 | 12:14 PM
ddawson's Avatar
ddawson
Here is a great video from Paul as well.
http://www.youtube.com/watch?v=yaQwPQTenMg
Old Feb 6, 2017 | 12:16 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It sure clears up the area around the trans. I do not see one getting the stock bracket out with out removing the crossmember to do so.
Jebby
Old Feb 6, 2017 | 12:31 PM
ddawson's Avatar
ddawson
It can be done pretty easy but it's tight.
Remove the left side exhaust pipe and transmission mount so you can lower it. Also remove the center console so you can access from the top.
Old Feb 6, 2017 | 12:42 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I had the trans out and it still was a pain.....
I suppose it could be done with some finesse.
Jebby
Old Feb 6, 2017 | 01:15 PM
Jeff k's Avatar
Jeff k
Did GM divorce the shifter from the trans just to eliminate vibration/ movement? I also wonder why they did not make the cross member removable as in the automatic models? It would have made life a bit easier! Things that make one go "Huh"?
Old Feb 6, 2017 | 02:17 PM
jim-81's Avatar
jim-81
I always wondered that, if the mounting holes are there in the trans why does the stock shifter not attach there?
Old Feb 6, 2017 | 03:01 PM
MelWff's Avatar
MelWff
It did attach to the transmission for the C2
Old Feb 6, 2017 | 03:06 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
For what it is worth the stock shifter in my 69' 427/400 was a slick unit....throw was kinda of long but it worked very well.
I went with the Hurst on the 72' as it has stops....
Jebby
Old Feb 6, 2017 | 05:31 PM
theandies's Avatar
theandies
If you have an Muncie (not sure all were like this) but you'll notice two different holes in the shifter linkage arms that attach to the transmission. They are long throw and short throw holes. I changed mine to the short throw holes and it made a big difference. At the time I also rebuilt my shifter which also helps a lot. I'm happy with the results and for the most part it was a free mod (not counting the shifter rebuild kit of course).
Old Feb 6, 2017 | 06:02 PM
ON 8TH's Avatar
ON 8TH
Back in Philly I used to chrome plate em. I don't know where thay do em now tho. Proably offshore,was a job between Job thing.
Old Feb 6, 2017 | 09:10 PM
Jeff k's Avatar
Jeff k
I don't mind the factory shifter. The throw is a bit long and eventually starts contacting the console opening. I always liked the reverse lockout feature, wish the Hurst had that option.
How many of you out there have a memory of laying on your back under the car either on the road or in a parking lot freeing up the linkage after getting the trans locked up in two gears?
Ahh, the good old days!!!!
Old Feb 7, 2017 | 08:57 AM
theandies's Avatar
theandies
If your car has the short throw holes you won't come close to the console cutout.
Old Feb 7, 2017 | 09:14 AM
Jeff k's Avatar
Jeff k
Thanks, that's good to know!
Old Feb 7, 2017 | 09:17 AM
BEJ's Avatar
BEJ
Paul's videos are great. I rebuilt a Super T10, with no experience, just from watching his videos. Very informative.
Old Feb 7, 2017 | 12:00 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I always assumed GM moved the shifter to the frame mount,
to minimize vibrations from the transmission driveline.
To Shifter change
