About 4 years ago I had Lars rebuild my Holley 650 Street Avenger. I sent him the carb, he overhauled it and sent it back. All I did was install it and drive (plug and play). I have made -0- carb adjustments during the past 4 years and it's been running SUPER during that time. I sent my Vette to my mechanic for a professional tune up and he called and said all he had to do was adjust the timing. When he pulled two plugs, they looked like I had a fuel injection system and not a carb...he decided that I did not need new plugs...they were in perfect shape! That says A LOT about Lars and his work. THANKS LARS!!!:thumbs :
Stuart's Holley was actually an interesting build - there are few carbs that I can specifically remember after 4 years... His Holley S/A was running lean, as they all do, but his was really bad... I always do a first test run of the carb on the run engine in the "stock" configuration, just to verify the baseline. The carb was running like a New York garbage truck, but I kept it "forced running" while verifying float levels and mixture screw settings. Idle mixture was off-the-scale lean, and the carb finally had a violent lean-mixture backfire which caught the run stand on fire. Luckily, I have a fire extinguisher within arm's reach of the power kill switch... But the entire carb had to be torn down and run through the hot tank again to get it cleaned up - along with a one-hour cleanup of the shop area. After a little re-jetting and "creative setup," the second test run was quite a bit more successful..
Lars
Your comparison to a New York garbage truck makes me wonder if the NYC Sanitation Dept. has been sending you their carbs?
Also, did you use a dry chemical or a CO2 extinguisher on that fire? At first I thought you may of grabbed a can of alternate fire extinguisher liquid.
When you're that good, you really don't need 'luck'....
Same here, I sent him my 73 Q-jet and he rebuilt it. Mounted and hooked-up,
and has been running for over 3 years and has not skipped a beat.
He's the best.
This Lars guy is a dangerous person! I've personally witnessed him putting a hole in a guys rear fender with a BIG hammer!!!!
Fake news comes to the Corvette forum! Lol.
we've hit a new low spreading fake news and quoting Thomas Jefferson in the same thread,how far have we sunk?
lower than the float level of a pro stock with 3 p.s.I of fuel pressure that's how low.
There's another photo somewhere of that hammer punched through the quarter panel... right before Les tackled me and strangled me as shown above. Now, how can that be fake...?
Originally Posted by Jim Shea
That's the hammer he uses to tune the linkage so that the carb reaches WOT with your foot on the floor.
Jim
That's correct. I keep that hammer in a drawer marked, "QuadraJet Tuning Tool."
I don't know WTF the fake news comment is about Lars, but I think I also still have that other pic of you and Les somewhere!!! Gotta search the hard drives for that one!!
Well, if you used that quadrajets adjusting tool on.the fender of a Corvette then I'm mistaken about fake.news . And accept my congratulations as I've at times.wanted.to take a hammer to a Corvette.lol
