Flushing a cooling system to install a Dewitts
My concern is flushing the green out sufficiently to avoid problems with the HOAT. No matter how well I flush the system, most likely there will remits of the green. Do I make the switch or stay green?
Regardless, If I stick with the green, I'll just flush it every 2-3 years. I was hoping somebody went thru the process of switching to the Zerex and if it presented any issues.
I changed out the radiator on one of my DD, the 01 grand prix, at 180,000 miles after leak developed...Dexcool for the first 60,000 miles and then Green coolant until today...200,000 miles on the motor.
My 94 Mustang GT with 32,000 miles on the car still has the OEM aluminum radiator and has used Green coolant for all of its life..bought new.
Use Distilled water and green coolant in the Dewitts and change it every 5 years or so and you will be fine. no need to create extra work for yourself...I have found consistently over the last 35 years working on cars, the service/change interval generally (not always) is much more important to the longevity of most parts, then the actual fluid used during the service.
I still think my Dewitts in the 78 C3 with green coolant is fine, as I stated, and observed in 2014. That radiator is now 10+ year old and zero issues with the green coolant.
And this from a very reputable guy on the Z06 forum:
"Those lawsuits are crap. By the way you can sue over anything but that doesn't mean you have a case or that you even win. I haven't heard of GM paying one cent toward those law suits other than defense costs.
I have been using Dexcool since I got my 97 Corvette back in 97. Over the years since I have had owned 7 cars that had Dexcool. Four of them went the 5 years before changing coolant with no issues. It looked like the day it was first put in the car. One of those four went through a second 5 year change with no issues with the coolant. Again it looked like new when I changed it. My 03 Tahoe is coming up on its second 5 year change in Dec of this year. Probably will change a couple months earlier so I don't have to do it in the cold. Coolant still looks like it did 4+ years ago when I put it in.
It is in millions of cars and not causing problems. You can read the lawsuit info on the web and see the whining type of person who is involved and you can look at actual trouble free results over many years with millions of cars. Do you side with the whiners or the facts?
Bill "
Not that it make any difference...and most people will not do it due to the costs involved....BUT....Check out Evans coolant. See for yourself.
http://www.evanscoolant.com/?gclid=C...FZUkgQod60cEyg
Check out the video with Jay Leno.
DUB
Pull the block drains, one of the heater hoses, connect your garden hose to the open heater hose, put the radiator cap back on and turn on the water. You could even pull the thermostat if you're feeling real frisky.
