car pulls left with brakes
take a cold car with cold brakes out and drive around the neighborhood, selectively applying your brakes on and off from different speeds. get the car home and check the heat of your rotors with your fingers. ( watch out may be very hot). your coolest rotor will be the one not clamping the same as the other. that is where your trouble is. check your rear rotors for heat also. one rotor may be heat glazed or a hose may not be passing fluid, or a caliper may be seized. or your pads are contaminated.
if the temperature is the same then you have a suspension issue with alignment while braking and your braking system is fine.
Turning a wheel by hand with a helper applying slight pedal pressure absolutely does check for complete failure, as in a frozen caliper or a totally collapsed hose. It's a very basic starting point.
Please don't press your fingers up against a hot rotor, borrow or buy a laser type thermometer. I bought a Raytek online, fairly inexpensive. I am sure H.F. has them.
Before checking rotor temps, I would do a basic bleeding on the right side to check for good fluid flow/pressure. When you crack open the bleeder, it should have some pressure to it until the helper pushes the pedal to the floor. If not, the hose could have some internal restriction.
make sure all is equal on both sides.. clean pads, rotor surface, no air in lines, bearings equal tightness,
plugged up distribution block under your master cylinder? crimped line?
do your heat test again..
Because.... assuming that the rotors are are above minimal thickness standards ( minimal thickness is 1.215")...and that the run-out is correct (very important)....and that the front wheel bearings are set correctly..also very important.
But simply swapping out rotors is not going to do anything. Because the previously mentioned inspections and set-ups that need to be checked would verify IF there were an issue with a badly warped rotor.
Swapping out rotors that have been checked is not like swapping out spark plug wires.
I was under the understanding that the brake guild flow was good and not being restricted. I am still feeling that this is the problem is fluid flow.
OR...It just may require you to obtain a brake pressure gauge and measure the PSI of the system at each front wheel.
And this is also assuming that the steering components on the car are GOOD....and no worn out control arm bushings, etc. Becasue...fit the caliper is GOOD...but when it is applying pressure...the entire control arm assembly is moving....thus...changing how the car is tracking. Also INSPECT all weld on the lower control arm to make sure that are GOOD...because I have seen my fair share of the welds popping and thus...changes EVERYTHING when you hit the brakes....or make aggressive turns.
DUB
I guess you've never seen a rotor that was glazed.
Maybe think about what you suggest next time so people do not waste their time doing something that will not help....and THEN maybe I would not have to clarify WHY your idea has very little merit UNLESS tests have been performed. Simple as that....and if I 'spell it out' in a manner that offends you....that's all on you. I was not offensive towards you in my reply.
And if you can fell his frustration at this point in this process of finding problem...because I can......suggesting what you did was just giving him a false hope... UNLESS the other tests were preformed first.
Just trying to ..whats that...oh yeah....offer advice on the problem and SAVE the guy some time....and get it repaired at the same time.
IMAGINE THAT...someone getting OFFENDED in what I write.
BUT...'C34ME'...if you want to go ahead and swap the rotors and give feed back if the problems is now on the other side or the same side.
DUB
SO...blindly swapping rotors or putting them back on and not knowing where they were located initially in regards to the wheel studs...can cause the rotor run out to be severe enough to cause for brake caliper issues.
DUB
DUB
Dot 5 brake fluid is Silicone based.
Just in case I would clean the rotor with rubbing alcohol and brake cleaner. I would scuff the rotor with 400 paper.
Has anyone looked at the power steering setup. If the valve is sloppy or the cylinder is leaking internally it can cause problems.
If the trailing arms are sloppy that can cause rear steer.
I did see a mention of a temperature difference in the front rotors. If they are the same brand, and thickness then I would think about rotor or pad contamination.
I the old days (>50 years) we had an adjustable bar we put on the seat and brake pedal to apply some pressure on the brakes. We would then use a torque wrench and measure the torque on each side to turn the wheel. Usually gave the answer. Sometimes you could also find a suspension issue or component that was questionable.
Hope you find the issue.
. But if he drives under 5 MPH...and taps the brakes and it pulls...to one side...then I feel it is a brake pressure/fluid issue.Hope you find the issue.
DUB
