Lift - off hood?
Old Feb 26, 2017 | 05:23 PM
steersdad's Avatar
steersdad
Default Lift - off hood?
I owned a 440-6 pack coronet years gone by. which had a lift off hood. 4 hood pins held it in place when racing. I'm thinking of doing the same thing with the hood on my car. It has a relatively light weight Motion hood (427 with open ended stinger scoop built on top).
I decided this is a good idea when I bashed my noggin into the hood latch. Blood streaming down my face, and curses that would make a Navy Chief blush... I said to myself, self, why don't you make the hood just lift off"?
Has anyone done this with their Vette?
If so, how did you like it?
My hood is light enough for me to take it off myself. I have a stock hood which seems to weigh quite a bit more.
Old Feb 26, 2017 | 07:08 PM
Scottd's Avatar
Scottd
I considered this option but stayed away from it because Im ALWAYS opening my hood. It just doesnt seem practical for a daily driver.
I did want to add hood pins, but never found a way to mount them.
Old Feb 26, 2017 | 07:12 PM
redvetracr's Avatar
redvetracr
Dzus clips
Old Feb 26, 2017 | 08:06 PM
steersdad's Avatar
steersdad
Dzus quick turn fasteners are a good idea. Pins are easy too.
Fabricating mounting brackets is simple enough.
Mine is not driven daily. I got pretty good pulling the hood off the R/T and setting it on the roof.
Old Feb 26, 2017 | 08:48 PM
7t9l82's Avatar
7t9l82
I've had lift off.hoods with Dzus fasteners and hood pins. I prefer the Dzus fasteners but hood pins give the option of using some small keyed alike padlocks for security. I may do something like that myself. Go for it.
Old Feb 26, 2017 | 09:33 PM
The13Bats's Avatar
The13Bats
On my daily driver 66 i had just lift off hood, it was basically a skin with l88 scoop, i could whip that baby on and off really quickly, i used 4 cheap mr gasket style pins as i wanted that look and yeah, my dad a retired navy plane tech all but begged me to allow him to do dzus on it,
The key to this mod idea to me is a very light hood.
Not to high jack but dont some racers have the full clip quick removal with dzus?
Old Feb 26, 2017 | 10:21 PM
BLUE1972's Avatar
BLUE1972
Saw one on Flee=bay in the fall with rear hood pins and regular hinge in the front.
It was an L88 hood if I remember correctly.
Old Feb 27, 2017 | 08:11 AM
7t9l82's Avatar
7t9l82
I had several race cars in the 70's and 80's that the front clip and trunk lid were all held on with Dzus fasteners
I'm leaning toward doing it again.
Old Feb 27, 2017 | 11:39 AM
The13Bats's Avatar
The13Bats
On a c3 front clip i have seen the dzus on the fender in front of the door where it would be bonded but how was the front nose tackled?
Old Feb 27, 2017 | 12:05 PM
7t9l82's Avatar
7t9l82
Start with a race weight front end weld up some metal rod for a framework.build a simple crossmember and drill a couple holes for your framework to sit into. put some Dzus fasteners around to steady everything . On a street car you'll need to figure out headlights but there are much more and better options than we had way back then.
I still have a 496 with a Lenco up at a buddies shop,but I couldn't cut this car up but I may find something in the future.
Old Feb 27, 2017 | 12:12 PM
The13Bats's Avatar
The13Bats
There is a central florida cat with a c3 set up like a tubbed drag car huge blower etc,
His whole front clip he and a buddy would pull off sit beside the car at a cruise, i never paid attention to headlights or how it fastened, seems headlights were recessed style,
Wish i had paid more attention,
Old Feb 27, 2017 | 12:21 PM
7t9l82's Avatar
7t9l82
We live close to each other if we find an opurtunity to meet up sometime I could show you easier than tell you on the forum.
Old Feb 27, 2017 | 01:12 PM
redvetracr's Avatar
redvetracr
the 2/3 thick body on my vintage racer (below) comes off in a matter of minutes
Old Feb 27, 2017 | 01:38 PM
joewill's Avatar
joewill
if light enough I suppose it can be done by one person.. but high potential of slipping or losing leverage and dropping and scratching some paint, etc..
Old Feb 28, 2017 | 02:21 PM
chevygod's Avatar
chevygod
As I'm (re)starting work on my '71 basket case outside of a garage, I knew I would need the hood off and on repeatedly, and didn't want to futz around with the bolts. I found a set of quick release hood hinges that were for sale a few years back.
I can R&R the hood single handedly, but my cars paint is fuggly. 2 people should be used for nicely painted car. Some issues setting them up and aligning the hood, but my car has a ruined nose, so a nicely aligned front clip may be better. Also, as I'm not driving the car I don't have the prop assy tightly bolted, so I just unthread it and lay it down when I pull the hood. After having them on the car for 5 months and the hood off and on a dozen times while working on it, I'm happy with them.
Here's some threads talking about them:
https://www.corvetteforum.com/forums...ood-hinge.html
https://www.corvetteforum.com/forums...od-hinges.html
Not as cool as hood pins, but gets that thing outta the way when working on the engine.
Best,
Tom
Old Feb 28, 2017 | 08:12 PM
The13Bats's Avatar
The13Bats
Best,
Tom
I have several sets of hinges i might try fabbing up a pair,
To Lift - off hood?
