Rebuilding Calipers.
Old Sep 24, 2002 | 03:12 AM
Blues77's Avatar
Blues77
Default Rebuilding Calipers.
Don't even know where to start or what to order. Please help.
Old Sep 24, 2002 | 03:23 AM
paintdaddy's Avatar
paintdaddy
Default Re: Rebuilding Calipers. (Blues77)
Whats wrong with swaping them for some rebuilt ones,much easier and less headache. :yesnod:
Old Sep 24, 2002 | 03:31 AM
Blues77's Avatar
Blues77
Default Re: Rebuilding Calipers. (paintdaddy)
The calipers dont look stock so I dont think they need to be honed and all that, but sealed up and whatever else needs to be done. I did a search but couldnt find much. Whats this talk about the O-Rings and all that.
[Modified by Blues77, 1:32 AM 9/24/2002]
Old Sep 24, 2002 | 03:36 AM
72rdstr's Avatar
72rdstr
If you must...
Go to Autozone (or NAPA, Checkers, etc...) and ask for caliper rebuild kits. It would be a very good idea to pop for a cylinder hone too.
IMHO, don't rebuild; replace. Autozone has lifetime warranty for cheap.
I rebuilt all four, two leaked (had rust in the bottom of the bores and I thought I could save them). This cost me the time involved in the rebuild plus new pads for front and rear!
Old Sep 24, 2002 | 07:12 AM
Turbo-Jet's Avatar
Turbo-Jet
Yeah, I also recommend replacing with remanufactured calipers with stainless sleeves. I was thinking about rebuilding mine, until I disassembled them and was shocked to see all the rust pitted surfaces! Just not worth it, and brakes kinda need to be reliable. ;)
[Modified by Turbo-Jet, 3:12 AM 9/24/2002]
Old Sep 24, 2002 | 07:22 AM
Disco_Mike's Avatar
Disco_Mike
i bought rebuilt stainless steel calipers from vette products of mi. i lost a coupla bucks because the cores were foreign produced. well worth the investement. i believe rebuilding calipers yourself is not worth the effort, unless you're really into these things.
Old Sep 24, 2002 | 01:04 PM
TedH's Avatar
TedH
I tried rebuilding using a kit from Advance Auto. But, given the hassle and fact that I ended up replacing the calipers two years later anyway, I'd recommend a pair of re-sleeved/rebuilt calipers from one of the parts houses.
Be warned though, your calipers have likely been re-sleeved already. If that is the case, you will pay full price (including core charge) since, once sleeved, they can't rebuild again (at least that is the line VB&P used with me). I think they gave me only 'one caliper' worth of core refund...
Some brake suppliers offer brand new cast iron Delco Moraine units without core charge (essentially same price as rebuilt unit with core charge).
[Modified by TedH, 1:08 PM 9/24/2002]
Old Sep 24, 2002 | 01:57 PM
Koz
Guest
Posts: n/a
Autozone with lifetime warrantee. It was fun to take the caliper apart and see how it looks/works etc.. then put it back together and buy a rebuilt.
Old Sep 24, 2002 | 02:09 PM
honaker's Avatar
honaker
Unless you have access to a machine shop, rebuilding them is a temp fix. Autozone has some very inexpensive rebuilt ones like everyone else has been saying.
Old Sep 24, 2002 | 02:12 PM
FastGlass79-85's Avatar
FastGlass79-85
:seeya I have to agree with everyone else....GO WITH REBUILTS :yesnod: :yesnod: I tried rebuilding my originals and it turned out to be a big waste of time :smash: :seeya
Old Sep 24, 2002 | 02:19 PM
kingdavidrules's Avatar
kingdavidrules
not that im saying something different than anyone else , gotta go with purchasing rebuilt ones , there relatively cheap , i paid $80 each with mine as cores. now im not as hessitant to drive my daughter around.
Old Sep 24, 2002 | 02:24 PM
mrvette's Avatar
mrvette
Blues, contrary to what everyone else says.....like Me 7 years ago, pull all the damn calipers apart, and see if they are stainless lined allready...if they are, as mine were, you do NOT need new calipers, kits with O ring pistons will be fine...end of story...toss the springs from behind the pistons, not needed....VBP is a good source for parts,, do all new hoses, steel lines are common as water and can be obtained locally, stainless is great for those who just have to go the VERY best, but a waste of money in reality...
I"d just do the master cyl on a local exchange, cheaper.....
I"d also do DOT5 fluid, it precludes rust....
check the rotor runout with calipers off and lug nuts on....hopefully they are not still rivited in place.....anything in runout you can see and feel is out of spec......but with O ring pistions and no springs...i'ts not nearly as critical as function as a stock setup....
obviously go with the usual brake checks as a normal car...in addition....
GENE
Old Sep 24, 2002 | 05:01 PM
Todbo's Avatar
Todbo
Default Re: Rebuilding Calipers. (mrvette)
mine were already sleeved also , I bought the o-ring rebuild kit from vbp , easy fix
Old Sep 24, 2002 | 05:30 PM
Jvette73's Avatar
Jvette73
Default Re: Rebuilding Calipers. (Todbo)
I just bought the seal kits from autozone. I used 320 grit wet/dry sandpaper with water to clean the pistons and bores. Havnt had any problems with the calipers since. I do however still need new pads since the ones on there now are glazed and causing fade. The pedal is still hard though so my calipers are sealed up good. But when the pads get hot they dont work very well.
Old Sep 24, 2002 | 09:15 PM
keith72's Avatar
keith72
I bought rebuilt w/ stainless sleeves from The Last Detail in Tucker, Ga. for
$65 each. I wouldn't try to rebuild them cause I don't think the savings are worth it. I'm having to stick to a budget for our 72 rebuild, and I would rather spend the right money on brakes, suspension parts, etc while we have the opportunity. These are things that you don't want to do very often, so why take a chance?
My .02
Old Sep 24, 2002 | 10:19 PM
SharkAttack's Avatar
SharkAttack
Default Re: Rebuilding Calipers. (72rdstr)
If you must...
Agree. I rebuilt a few of these, only to have them leak again within 12-18 months. Do it right the first time.
To Rebuilding Calipers.
