DeWitts New Coolant
Old Feb 28, 2017 | 12:16 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Default DeWitts New Coolant
DeWitts Pre-mixed Coolant is specifically formulated to be a premium, all-season coolant/antifreeze for high performance automotive engines. It contains a patented low silicate corrosion protection package that prevents rust and corrosion and is specifically engineered to protect materials used in modern performance engines. DeWitts High Performance Coolant offers a more advanced additive package than standard “green” coolants and maintains better thermal conductivity and heat transfer than propylene glycol (PG) based coolants. The advanced additive package contains special anti-foam agents to reduce water pump cavitation and increase cooling capacity. DeWitts High Performance Coolant meets GM 1899M, Ford ESE-M97B-44-A, and Chrysler MS7170 specifications and is compatible with all nationally distributed coolants and liquid coolant additives. System protection is maintained from -34°F to +265°F when used with a 15lb. radiator
Product Page
Use promo code 301promo for a 15% discount
Old Feb 28, 2017 | 04:03 PM
ignatz's Avatar
ignatz
Good to know this exists. I'm probably due for a change. Brings up a related question - are there any coolants or additives we shouldn't be using in your radiators? I imagine you can't be brand specific so what should we look to avoid in general? And for changing over to your coolant, any guidance on flushing out the old stuff?
Old Feb 28, 2017 | 05:37 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Not really, just use common sense. The biggest problem by far is using tap water from a bad source. That's why I highly suggest purchasing a pre-mixed package because it takes all the guess work out of it.
Old Feb 28, 2017 | 06:31 PM
DUB's Avatar
DUB
Any success on our radiator project???
DUB
Old Feb 28, 2017 | 08:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Bump for Tom...
Vendors.. no matter how much they spend here can't bump their threads for two days after their last post unless there is a question so we depend on others to bump our threads.
So bump for Tom, take it to the top.
Ernie
Old Feb 28, 2017 | 09:53 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Tom,
I've used ZEREX in one of your radiators since 2010. How does your new product compare?
Thank You,
Dave
Old Mar 1, 2017 | 10:04 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by claysmoker
Tom,
Thank You,
Dave
Zerex is a good one, very similar to ours.
Old Mar 1, 2017 | 10:06 AM
claysmoker's Avatar
claysmoker
Thanks Tom. Your product is the best.
To DeWitts New Coolant
