Too much timing?
Old Mar 1, 2017 | 12:01 AM
Moser28's Avatar
Moser28
Default Too much timing?
1981 Corvette no computer. New Engine New HEI distributor with vacuum advance . Advance is at its lowest setting. Hooked to manifold vacuum. Car idles great runs great even at WOT but on the interstate slight knocking on acceleration only. I am thinking I have too much advance. Total timing is 36 deg at 3,000 RPM. Initial is around 17. Any thoughts or suggestions to my issue?
Old Mar 1, 2017 | 04:07 AM
usmilret's Avatar
usmilret
Your timing is too far advanced. Did you disconnect the vacuum advance and plug it before you checked the timing?
Old Mar 1, 2017 | 05:53 AM
SH-60B's Avatar
SH-60B
Back off total. What octane gas are you using?
Old Mar 1, 2017 | 05:58 AM
theandies's Avatar
theandies
What's your advance all in? What vacuum can are you using? Sounds like your too advanced in light throttle conditions.
Old Mar 1, 2017 | 11:53 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Your initial/mech'l sounds fine but to check, disconnect your vacuum advance and take a test drive. If it doesn't ping under acceleration, then you have too much vacuum advance at part throttle. Retard your vacuum advance.
Old Mar 1, 2017 | 01:19 PM
lars's Avatar
lars
Your timing is fine. It's your vacuum advance curve that's too long. Limit your vacuum advance to 10 - 12 degrees. Most likely, your vacuum advance is pulling in about 18 - 20 degrees of vacuum advance, and that's your problem.
Lars
Old Mar 1, 2017 | 02:30 PM
Moser28's Avatar
Moser28
This is exactly what I was thinking. I did disconnect the vacuum when setting the timing. The knock is heard at light throttle condition, everything else is fine. I was thinking that my curve needed to be adjusted. I am all in at 36 deg BTDC at 3000rpm. So i need to keep it connected to manifold port? At its lowest adjustment vacuum advance is around 10.
When I had the CCC system all I had to do was set initial timing and I was done so all of this is new to me and adjusting the curve is new to me as well. When changing springs would I need heavier springs?
Thanks for your help!
Old Mar 1, 2017 | 02:31 PM
Moser28's Avatar
Moser28
I always use 93 Octane.
Old Mar 1, 2017 | 02:45 PM
MelWff's Avatar
MelWff
Default springs
There is nothing wrong with your springs. What do you mean by "at I'ts lowest adjustment vacuum advance is around 10". Normally you can not adjust the vacuum advance, you have to change the can or modify the slot on the unit.
Old Mar 1, 2017 | 03:07 PM
Moser28's Avatar
Moser28
The can has an allen wrench adjustment.
Old Mar 1, 2017 | 03:23 PM
BLUE1972's Avatar
BLUE1972
Try adjusting the accelerator pump for more fuel. If no other issues this may help.
Old Mar 1, 2017 | 03:24 PM
Bloodzone's Avatar
Bloodzone
I run the AR12 can PN VC1838. I could never get the allen wrench can to work for my needs.
I was mistaken I use the AR31 can connected to manifold vacuum not the AR12.
Old Mar 1, 2017 | 03:51 PM
Moser28's Avatar
Moser28
I can't back this one off any more than it is already. If I modified the slot which end would I lengthen?
Old Mar 1, 2017 | 03:56 PM
Bloodzone's Avatar
Bloodzone
You shorten the hole if you want less advance from can.
Old Mar 1, 2017 | 05:40 PM
Moser28's Avatar
Moser28
That makes sense. Thanks for the help guys. I always want to do everything myself and I know I can do it with guidance from this forum. I will post my results this weekend.
Old Mar 1, 2017 | 11:04 PM
real77's Avatar
real77
Cruising
Maybe EGR not fonctionning correctly. If EGR doesn't open in that particular case, it will PING. It hapenned to me long ago.
Old Apr 5, 2017 | 12:49 PM
Moser28's Avatar
Moser28
No EGR.
To Too much timing?
Old Apr 5, 2017 | 04:41 PM
theandies's Avatar
theandies
I have the same problem. No matter where I set my initial/mechanical timing my cruise timing (vac can and I like the throttle response of an aggressive timing curve) goes way too high and I get partial throttle ping. Lars makes a vacuum timing limiter and I'm waiting on his reply to get one.
Right now I'm running without vacuum advance and it's fine. The only issue doing that is a decrease in gas mileage and it runs 10 to 20 degrees hotter depending on OAT. I don't want to run without vacuum advance over the summer so I'll install Lars gizmo. I thought about getting an adjustable can but I don't trust them just as you are finding out.
Old Apr 8, 2017 | 01:57 PM
real77's Avatar
real77
Cruising
Default Egr
No EGR.
Pinging problem with mine was EGR not working (there were no vacuum signal at EGR). After fixing it EGR was working and no more pinging.
Old Apr 8, 2017 | 04:23 PM
v2racing's Avatar
v2racing
As Lars said, it's your vacuum advance. I made a limiter for mine out of a thin piece of strap steel. One end has a slot for the vacuum advance rod to go through and the other end is slotted for the single screw at the end
of the vacuum mount. You can then adjust it to the amount of advance that you need.
Mike
