Manifold vacuum
Old Mar 1, 2017 | 12:24 AM
Antz81's Avatar
Antz81
Default Manifold vacuum
What should a stock (except for removed AIR, EGR, EFE, with long tube headers and dual exhaust, no cat) have for the manifold vacuum at idle? Currently I'm getting 16", but think this should be higher. (my brothers 82 silverado gets 19") I'm not completely certain on my cam but I do believe it is the stock cam.
Old Mar 1, 2017 | 12:59 AM
7T1vette's Avatar
7T1vette
If the engine has lots of miles/wear and you still have the stock cam in it, you should be getting anywhere from 18"Hg to 20"Hg. To determine the max vacuum your car can produce, you need to disconnect and block-off ALL manifold vacuum sources from the engine and THEN check it. If you get a lot more vacuum, you will have one or more leaks to find and repair. Just add stuff back one-at-a-time and identify the system[s] that cause the leakages. Then chase them through that line until you identify it.
Old Mar 1, 2017 | 01:12 AM
Antz81's Avatar
Antz81
I've disconnected everything but the brake booster (which i am 100% sure is not leaking) and still get the same. The engine idles fine and doesn't seem to be lacking in power. I've had a thorough check for vacuum leaks, but can't find any.
Old Mar 1, 2017 | 05:57 AM
SH-60B's Avatar
SH-60B
You can experiment with the ignition timing in search of higher vacuum.
Old Mar 1, 2017 | 11:20 AM
Antz81's Avatar
Antz81
I've checked with 6, 8, and 12* initial timing, all give the same result. Currently I'm on 12* for the small performance gain.
Old Mar 1, 2017 | 11:22 AM
Antz81's Avatar
Antz81
Vette is a 1981 4 speed. I thought I had this in the 1st post
Old Mar 1, 2017 | 11:52 AM
MelWff's Avatar
MelWff
what rpm when you get the 16" reading?
Old Mar 1, 2017 | 11:54 AM
Antz81's Avatar
Antz81
700rpm
Old Mar 1, 2017 | 02:43 PM
MelWff's Avatar
MelWff
You unplugged the computer connection at the distributor and the vacuum line before setting the timing to 12 degrees initial?
Old Mar 1, 2017 | 04:10 PM
Antz81's Avatar
Antz81
EST connector on the distributor was unplugged. No vacuum line for timing on an 81
To Manifold vacuum
