I got the timing tape today and just need some help on how and where to apply it?
I presume just put the 12 deg mark on the tape and line that up with the white mark on the harmonic balancer seeing that the timing is 12deg BTDC? Please tell me if I'm doing it wrong?
The line on the balancer should indicate TDC when it is inline with the 0 deg mark on the timing cover. So the 0 deg on the timing tape should line up with the line on the balancer.
In regards to the bold section in your quote. You mean the 0 deg on the timing tape should line up with the 0 line on the timing cover, yeah? So I'll make sure I put the tape on so the 12 deg mark lines up with the line on the balancer, that will mean the 0 deg mark on the tape lines up with the 0 deg mark on the timing cover.
I measured the balancer and to my surprise it measured 6 3/4 inch. That must be what the standard ones were.
Tested it tonight. Unfortunately when I got up to the 4000rpm test the tape flew off and I've been unable to find it since. I'll have a good look tomorrow when I have some day light.
Royal Canadian Navy
My L-82 was 8" in diameter. You can easily make your own timing tape and mark the degrees on it with white paint.
Like Resdoggie I use white paint, white out to be specific, the stuff we used to use to make corrections in typing.
It's very visable with the timing light. I also use it on the pointer.
If you get ambitious you can also mark your balancer every 90*. This comes in very handy while setting valve lash. I even went so far as to put what cylinders were TDC at that mark. IE at 0* #'s 1 and 6 are TDC. So next to the 0* mark I also have those two mumbers written.
Good thing it flew off methinks as 0 deg on the tape should line up with the mark on the balancer, then when say 10 deg on the tape is pointed at by the pointer on the timing cover the engine will be at 10 deg before top dead centre.If the timing tape is the wrong length to wrap around the balancer completely or is too long the degrees indicated will be incorrect.
You can remove one spring from the centrifugal advance so you don't have to rev the bejesus out of the engine to find out what the max advance is!
I'm sure this is just a stock balancer however it measured 6 3/4 in diameter.
Originally Posted by REELAV8R
Say you have a 8" diameter balancer ( I believe this is the stock diameter). The circumference should be 2xPIxR.
PI=3.14
R= radius.
So in this case 25" in circumfrence. 2x3.14=6.28x4=25.12
Divide 360* by 25. You get 14.4. That's 14.4* of advance for each inch past 0* on your balancer.
So for 36* of advance divide 36 by 14.4. You get 2.5.
This means 2.5 inches from 0* on your balancer is 36* of advance.
Or just wrap a tape around your balancer to measure the diameter and use the above math to see where 36* should fall.
This is where the tape you buy should indicate 36*, or if the tape comes off or you don't use it.
Math, complements of Lars IIRC.
I'll measure the circumference and report back.
Oh ok I see your tape did fly off. Typical.
Once I know exactly what balancer I have then this could be another option for sure.
Why should the 0 deg mark on the tape line up with the line on the balancer? When I check the initial timing the line on the balancer lines up with the 12 deg mark on the timing cover.
So when I check total timing doing it your way would mean that the total timing reading would be out by 12 deg?
Fully understand if the wrong tape is on the balancer then the readings will be incorrect. The balancer measured 6 3/4 in diameter. I'll measure the circumference today and report back.
I think as long as I find out what the 4000rpm advance is, it should give me an indication of whether it's still advancing or not. If it's not at 36 deg at 4000rpm, I may have to go to the 5000rpm test.
Originally Posted by fishslayer143
before installing tape.... CLEAN THE DAMPENER
I did with cleaning solvent about 2 hours before applying the tape.
You can loosen the distributer hold down bolt slightly and turn the distributor counter clockwise until you have 36 total at 3,000 rpms.
Don't forget to disconnect the vac advance line and tighten the hold down bolt when done making the adjustment.
Marshal
Circumference of the balancer is 538mm (21.20inches). 21.20 divided by 3.14159265358979= 6.75 inches diameter.
Got a chance to go out and check the timing properly tonight. Superglued the same timing tape at both ends this time. Here are the results.
Marshal
Cool thanks Marshal. I'll try that tomorrow and hope it runs a little better
Adjusted the timing yesterday. Unfortunately I couldn't get the timing to come in at 36 deg at 3000rpm. The best I could get it was 36 deg at 2500rpm. The initial timing ended up at 17 deg and progressing from there.
Anyone know why my engine is like this? Could it be something else like carb tuning that is limiting it?
Royal Canadian Navy
Your getting close. Leave your initial @17*. Try using the next heavier spring on your dist'r weights. You can change the springs one at a time mixing spring ratings. This will increase the rpm's to reach the desired 36*@3000 rpm. You maybe ok right now but try for 3000 rpm and note any difference in performance. Once your curve is set, then onto carb tuning if needed.
Thanks rd. Like I said earlier in the thread, I already have a Breakerless SE ignition kit which I plan to install shortly. How will I know which springs to buy and where do you buy them from?
I'm not really familiar with Chev distributors or Chev engines for that matter. I tried to pull the rotor button off yesterday and it wouldn't budge, not sure whether there is a screw or something that needs to be removed first to even pull the rotor off. Any advice with this also would be helpful?
