Elecrical Draw
Old Mar 2, 2017 | 12:10 PM
J Mo's Avatar
J Mo
Default Elecrical Draw
I have a 72 and if I don't use the battery disconnect, the battery will drain in 2-3 days. Anyone have any suggestions as to what may be causing this ? Lights are not on. Could alarm cause this ?
Old Mar 2, 2017 | 03:16 PM
Peterbuilt's Avatar
Peterbuilt
See post 1 and go step by step and you will find your problem.
https://www.corvetteforum.com/forums...with-pics.html
Old Mar 2, 2017 | 04:58 PM
blue by you's Avatar
blue by you
get a test light and disconnect the pos cable pull one fuse and touch the test light to the pos cable and the pos terminal if the light does not light replace the fuse and move to the next fuse the one that light the test light when the fuse is out is the circuit that has the draw
Old Mar 2, 2017 | 08:37 PM
J Mo's Avatar
J Mo
Thanks I"ll give it a try!
To Elecrical Draw
