Headlights won't close
Old Mar 10, 2017 | 02:24 PM
CoolShark's Avatar
CoolShark
Default Headlights won't close
My headlights on my '72 suddenly stopped closing.
I can find no lose vacuum lines and everything else works. Any ideas?
Old Mar 10, 2017 | 03:03 PM
Alan 71's Avatar
Alan 71
Hi CS,
Have you done any work in the engine compartment or under the dash that may have caused this?
Are they still opening normally?
Are the headlights responding to the vacuum override switch below the steering column? It's the switch on the left.
With the headlight switch OFF…. pull down on the override…. the doors should open, but the lights won't illuminate.
Pushing up on the switch should close the doors.
Does that happen?
Regards,
Alan
This switch opens and closes the headlight doors.
Old Mar 10, 2017 | 03:46 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Alan is right.. If the switch is pulled it will block vacuum to the relay. If the switch isn't pulled, go to the small hose on top the relay and see if you have vacuum there. It takes vacuum on that hose to pull the relay up and close the lamps.
-Willcox
Old Mar 10, 2017 | 04:05 PM
theandies's Avatar
theandies
If they all of a sudden just quit and you've not done anything to cause it I'd suspect you've lost one or both of the actuator seals. Easy fix as you can buy a seal kit.
Old Mar 10, 2017 | 04:22 PM
Iceaxe's Avatar
Iceaxe
There are two types of Corvette C3 owners in the world. Those who own a Mity-Vac and those that will own a Mity-Vac.
Old Mar 10, 2017 | 06:25 PM
CoolShark's Avatar
CoolShark
They open fine, but won't close unless I do it manually. The over-ride switch is not activated. It is both lights, not just one. I put on all new hoses about 10 years ago, so it is not a cracked hose. The engine is too loud to hear a vacuum leak, though.
Old Mar 10, 2017 | 06:47 PM
Alan 71's Avatar
Alan 71
Hi cs,
It's odd that both relays or both actuators decided to fail together.
Is your headlight system in fact using 2 relays?
Are you certain that the red striped hoses haven't been disturbed in some way?
Regards,
Alan
Old Mar 10, 2017 | 07:25 PM
theandies's Avatar
theandies
Now I'm thinking the headlight switch itself.
Old Mar 10, 2017 | 08:08 PM
Dave J's Avatar
Dave J
Old Mar 11, 2017 | 10:17 AM
0Willcox Corvette
Former Vendor
Here is a video on how to test the components of the headlamp system:
1968-1982 Corvette Headlamp Vacuum Diagnostics Help
Old Mar 11, 2017 | 05:50 PM
CoolShark's Avatar
CoolShark
Thanks for your help, all and especially Wilcox with the handy diagram. I did find a loose hose that was not obvious.
Old Mar 14, 2017 | 09:37 PM
0Willcox Corvette
Former Vendor
Sweet.. glad you got it fixed..
Old Mar 1, 2020 | 07:46 PM
BarryB72's Avatar
BarryB72
Ttt
To Headlights won't close
