Fried My Car
Any Ideas...Again...please?
The timing light hot clip was on the alt batt term and shorted to the alt case and fried a wire or melted a link, i have no clue where the links are on his 78 or best way to explain how to test them, some of his wiring is aftermarket, he does have a meter no test light, and is basically novice on it....thanks and lets get his car going...
Chevy probably saved 10 cents per car to have a useless fusebox and "Fuse Links" everywhere.
If any of the C3 designers/project Managers ever read this...SHAME ON YOU!!! You could have saved tons of time/money/stress/tears on your costumers had you just put every fuse in one simple spot. Don't even get me started on the vacume headlight disaster you got going on. The whole system is a major "Keep It Simple Stupid" violation. The more I dig in this car (8 months and counting of digging...mostly 12 hour days) the more shocked I am at how flimsy these designs are.
Thats my rant.
I just want to drive my car before I get surgery... Too much to ask? Yes.
Anyway thanks forum, If ya can tell me more about the fuse links, I appreciate it. Somewhere between starter and engine harness there is no power.
Thats my rant.
Those fusible links are there to keep your car from burning down in the event that someone does something like you just did.
This drawing is for a late production 1977. Early production 77 had fuse link B under brake booster as member 75 described. Late model 77 moved both A&B fuse links to starter solenoid.
Fuse link A feeds your ignition switch and fuse block, fuse link B feeds your headlight switch. You say your headlights still work, this says current is still passing through fuse link B.
If it were me, I would disconnect the + cable from the battery, remove one fuse link, reconnect battery to identify fuse link A, leaving fuse link B unconnected.
If you have a needle type of probe for your meter, DC setting one lead to ground. You should get a reading on both sides of the (White or Black) capsule of wire of fuse link A. If you have the proper reading start working your way back testing at each connector until you reach the alternator.
Note: Where the page ends to the upper right the 2 #10 red wires go to the alternator.
Disconnect + cable again, reconnect fuse link B when your finished.
The 'fusible link' is the wire between the the 2 black rubber insulators.
The wire is of a smaller size so it fails rather than have the current pass on to the electrical component it's there to protect.
You can see the 'link' wire is smaller gauge than the larger red wire it 'protects'.
Regards,
Alan
These are from a 71…. might give you some help in locating the 'links' on your car.
Here's one at the horn relay.
Here's one near the wiper motor.
Here's the one that protects the starter.
Thanks could you tell me where you got this? I would love to buy and add to my personal collection
Signed,
Another Joe
