What is this thing?
Old Mar 18, 2017 | 08:47 PM
garrettb's Avatar
garrettb
Default What is this thing?
I found this hanging near the starter/solenoid. The wires are toast, and the sensor(?) is covered in black goop. The car is a 1982. Help!
Old Mar 18, 2017 | 09:16 PM
M. Young's Avatar
M. Young
Can you clean it up? Pull back some of the shielding and take a pic of the wire colors.
Old Mar 18, 2017 | 11:18 PM
The Punisher's Avatar
The Punisher
Looks like a fusible link
Old Mar 19, 2017 | 07:42 AM
Sluefoot's Avatar
Sluefoot
What a MESS!! U DO need to clean it up so everyone can get a halfway decent idea as to what we're lookin' at!!
Old Mar 19, 2017 | 07:50 AM
M. Young's Avatar
M. Young
One other suggestion might be to trace that wire back to its source if possible. That will help us figure it out as well.
Old Mar 19, 2017 | 09:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My WAG: auxiliary fan connector.
Old Mar 19, 2017 | 10:06 AM
garrettb's Avatar
garrettb
Thanks for the replies. If I recall, the wires were blue/green. I don't have my shop manual in front of me so I can't check that. I'll clean it up later and take another photo. I tried to trace the wires back to the source, but this connector becomes a part of the large loom tied against the firewall, and I'd have to take all the wires apart to look at it.
Old Mar 19, 2017 | 01:38 PM
j61man's Avatar
j61man
Default My guess
To me it looks like the connector to the knock sensor which is located further up the right side of the lower engine block. It is round cylindered shaped with a threaded stud sticking out of it. Your connector clips on to the stud with spring tensioned metal clips.
Old Mar 20, 2017 | 01:12 AM
garrettb's Avatar
garrettb
You're right! Turns out I am not the only one with this issue. I searched the forums, and although many people have the issue of the wire degradation, replacements are NLA. What are your thoughts in switching to a later version of the sensor? I couldn't see the sensor on my engine, but I will keep looking. My connector looks nasty. What rubber once existed has been turned mushy and gross by years of oil drips.
Old Mar 20, 2017 | 07:52 AM
Easy Mike's Avatar
Easy Mike
With no computers on 79s, what would be the purpose of a knock sensor?
Old Mar 20, 2017 | 08:06 AM
mobird's Avatar
mobird
My question as well
Old Mar 20, 2017 | 09:01 AM
garrettb's Avatar
garrettb
My car is a 1982
Old Mar 20, 2017 | 01:38 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by garrettb
My car is a 1982
Ooops. Not sure where I came up with 79.
Old Mar 20, 2017 | 02:23 PM
j61man's Avatar
j61man
The knock sensor is on the lower right side of the engine block about one inch ahead (forward) of the starter motor. It screws into a small round threaded hole in the block. Your connector may be fine once you clean it up and recover the wires. My connector is mostly a metal clip. The two sides are pushed outwards by an internal spring. Push the two sides together (finger tight) and the holes on the bottom will line up to capture the threaded stud of the sensor. Eckler's has a picture of the sensor available at http://www.ecklerscorvette.com/corve...nsor-1982.html but it seems to be on national backorder. I do not know about changing over to a later model sensor but if you find one with two wires it should be simple enough.
To What is this thing?
