Having fit problems with Dougs header side pipe
Old Mar 25, 2017 | 12:36 PM
Woody33's Avatar
Woody33
Default Having fit problems with Dougs header side pipe
Any suggestions?
Installed Dougs headers / still working on the side pipes
The drivers side header is 3" out from the side frame rail.
The passenger side so far appears ok it is 2" out from the side frame rail.
I will call Dougs on Monday- to see their opinion, but the drivers side pipe will not mount, just too far away, it is 1.5" from the back of the side pipe bracket to the frame rail ?
My car is. 1970 big block.
Has anyone else seen this? Could it be the header is just not right, I also had to heat pipe and add a ding as the Doug ding was in the wrong place for my steering box...
Old Mar 25, 2017 | 02:06 PM
Knerf's Avatar
Knerf
when you put the pipes on can you pull them in any or does it end up sticking out way far at the end?
maybe a pic would help to see how they are lining up
Old Mar 25, 2017 | 06:16 PM
bazza77's Avatar
bazza77
what do your engine mounts look like ?
Old Mar 26, 2017 | 10:48 AM
3JsVette's Avatar
3JsVette
Sorry to hear that. When putting a set of side pipe headers on a big block '68 Doug's were the only ones that fit without needing a hammer. As stated above check your mounts.
Old Mar 26, 2017 | 07:30 PM
flyeri's Avatar
flyeri
I had similar problems, Doug's and Hookers and new mounts. Right side pointed out and down. Left side was straight but pointed up. Both were further out than the old Hookers I took off. I sent both ceramic sets back and ordered Doug's painted and I had a guy that builds headers cut and align them. Then I had them coated. IF i have to do it again I will have them custom built.
To Having fit problems with Dougs header side pipe
