Starter wiring fuseable links
Old Apr 5, 2017 | 09:16 PM
mrit's Avatar
mrit
Default Starter wiring fuseable links
So my recently purchased 77 has some hack job wiring... Really bad stuff... I've been tearing it out and fixing everything, but i hit a stopping point with my starter wiring. This is what is currently on the car
Yep... They hacked it off... I know the black wire goes to the bellhousing bolt by the starter.
Been researching and came across a post by mds3013 showing this pic(hope he doesn't mind me borrowing it...)
Mine is missing the fuseable links at the end of the double red wire setup. I was curious what I should do about this? The cut off wiring I do have is 12ga, should I just step down to 14ga at this spot?
Old Apr 5, 2017 | 10:13 PM
Big2Bird's Avatar
Big2Bird
Most auto parts stores have fusable links.
Old Apr 6, 2017 | 07:26 AM
Alan 71's Avatar
Alan 71
Hi mrt,
Typically the proper protection for a wire is achieved by using fusible link that is 4 wire gauges smaller than the wire being protected.
Thus 12 gauge wire would be protected by a 16 gauge fusible link.
Regards,
Alan
Old Apr 6, 2017 | 08:25 AM
sparky77's Avatar
sparky77
I also have a 77 and my starter wires are screwed up ,I'm going to order a new one ,starter extension wire harness mine has air so the # is VSM7778AC it's not cheap at 80.00. They do make it for non AC cars also ,there should be two plugs near the top of you're firewall that it plugs into.
Old Apr 6, 2017 | 12:48 PM
mrit's Avatar
mrit
Ok cool, I didnt know I needed 16ga. Fuseable links are new to me, I've never had to deal with them before. Thanks
Old Apr 8, 2017 | 10:29 AM
sparky77's Avatar
sparky77
Advance auto has them GM 16 ga. link Dorman part # 85621
Old Apr 8, 2017 | 09:28 PM
7T1vette's Avatar
7T1vette
Fusible links are designed to "fry" when a dead short occurs. So, the insulation and terminal ends on fusible links MUST be non-flammable.
You can't use regular wire for making a fusible link. Well, you could...but if it blew, you would end up with
To Starter wiring fuseable links
