rear main seal replacement
Old Apr 6, 2017 | 07:58 PM
greggome's Avatar
greggome
Default rear main seal replacement
My 68 327 has started leaking oil. I have checked valve cover areas etc. but it seems to be coming from between the bell housing and engine block. It may be my rear main seal. Anyone replace one of these themselves on an early C3 like mine? DIY or take it to the shop?
Old Apr 6, 2017 | 09:08 PM
68notray's Avatar
68notray
Have to pull the motor to do it right
Old Apr 6, 2017 | 09:11 PM
63split63's Avatar
63split63
Default No need To Pull The Engine
You can remove the pan and the rear main cap without pulling the engine .
Old Apr 6, 2017 | 09:23 PM
Big2Bird's Avatar
Big2Bird
Not a lot of fun, but doable.
There is a certain Felpro seal that moves the wiper tad to fresh surface.
Maybe TimAT will chime in with that ##.
Old Apr 6, 2017 | 10:27 PM
OMF's Avatar
OMF
I just did this on mine last month, and on a friends corvette last year.
It's easy to do with the engine still in the car.
Here's the coles notes version....
-Drop the steering gear, pull the starter, pull the pan, pull the oil pump, pull the rear main cap....change seal and reassemble.
Don't buy a cheap seal, get the good one from Fel-pro 2912
One day job with a hoist, probably 2 days laying on your back....
Old Apr 7, 2017 | 07:48 PM
68notray's Avatar
68notray
By pulling the motor you have the opportunity to do other chores like clean & repaint engine, get good clean gasket surfaces, etc. Same amount of time, better result
Old Apr 7, 2017 | 09:03 PM
The13Bats's Avatar
The13Bats
A good 20 years ago my 66 with a
327 i dropped in started really leaking bad rear main seal,
I ran it up on ramps, recall having to disconnect steering rod, drop the pan and that related fun, and changing the seal was fast and easy, and i didnt line up where the seal meets top and bottom with main cap to give extra protection, i pushed one end if the seal around more, staggered the breaks,
It worked great did it alone in a long day, but that car was stick with no power stuff and if to do it again, yep, would pull the engine, it wasnt fun in my back,
Old Apr 8, 2017 | 12:52 AM
7T1vette's Avatar
7T1vette
Purchase a Viton rear seal...comes in two halves. READ INSTRUCTIONS CAREFULLY AND FOLLOW THEM. Offset each half-seal about 1/8" from the engine splitline so that the splits between the seal halves don't line up with the engine block splitline.
This is NOT a difficult job. Use care when inserting the upper seal half so that the sealing lip is not damaged (instructions will explain).
Did mine about 10 years ago...nary a drop since.
Old Apr 8, 2017 | 09:51 AM
greggome's Avatar
greggome
Thanks for the info. Is there a tool to press the top seal out and put the new one in? It looks like it can be a bit tricky to remove?
Old Apr 8, 2017 | 10:39 AM
OMF's Avatar
OMF
Its not tricky to remove at all, I just used a large diameter punch that was close to the same size of the seal end and tapped the seal to get it started. It just spins out around its own groove, and once started its easy to grab with some plyers and pull it out.
I used a bit of brakeclean to clean any oil residue and then lubed the new seal around the edge that contacts the crankshaft and then install. Yes using the litle tool that is supplied with the seal is essential to the job going smoothly, use it like a shoehorn.
This is one of the better seal out there to use, think its worth the extra money.
I https://www.summitracing.com/int/par...make/chevrolet
Old Apr 8, 2017 | 03:53 PM
greggome's Avatar
greggome
Thanks for the info, Cant imagine why you'd have to pull a motor just to replace these seals! Sounds crazy.
Originally Posted by sstocker31
Its not tricky to remove at all, I just used a large diameter punch that was close to the same size of the seal end and tapped the seal to get it started. It just spins out around its own groove, and once started its easy to grab with some plyersand pull it out.
I used a bit of brakeclean to clean any oil residue nad then lubed the new seal around the edge that contacts the crankshaft and then install. Yes using the litle tool that is supplied with the seal is essential to the job going smoothly, use it like a shoehorn.
Old Apr 9, 2017 | 10:47 PM
drwet's Avatar
drwet
Yes, no reason to remove the engine. Not my favorite job, but far less work than removing the engine. Do your homework and get the best seal you can. There are several different seals available and they are not created equal. I don't recall the details, but I have used the good ones and the cheap ones, and the good ones are definitely worth the money.
Old Apr 19, 2017 | 12:18 PM
Bergerboy's Avatar
Bergerboy
There are several versions out there - Fel-Pro seems to be the most recommended. But they offer a single lip, dual lip, and an offset lip version (supposedly to slightly shift the seal surface on the crank, if there has been a groove worn in by the old seal).
How to know which one to choose??
(mine is a '69 350, not the '68 327 of the O.P.)
Old Apr 19, 2017 | 12:27 PM
Big2Bird's Avatar
Big2Bird
Offset lip is best.
Old Apr 21, 2017 | 03:01 PM
peterman4551's Avatar
peterman4551
I'd take off the dust cover on the bell housing to be sure there is oil in the bell housing first. The rear of the passenger side valve cover can leak oil down that way. You may just need to tighten the valve cover bolts. Speaking from experince...
Old Mar 30, 2019 | 05:14 PM
Sbrown6422's Avatar
Sbrown6422
1st Gear
Default Rear main replacement
I did mine today. It took about 3 hours. It's a straight forward job. I used the one piece oil pan gasket and the felpro offset seal. I had no issues at all. You just need hand tools and a torque wrench.
Old Mar 30, 2019 | 08:42 PM
speedreed8's Avatar
speedreed8
Hopefully they got it fixed 2 yrs ago.
Old Mar 30, 2019 | 09:44 PM
7t9l82's Avatar
7t9l82
Takes about an hour and a half with these new electric tools. I put a deep milodon pan and melling select pump on at the same time. The felpro offset seal is a great idea. Put assembly lube on your rear main bearing .pulling the engine is nuts it's very straight forward..
To rear main seal replacement
