Temperature sender wire routing
Old Apr 8, 2017 | 03:12 PM
Rustman's Avatar
Rustman
Default Temperature sender wire routing
On a sbc, what is the wire routing to the temperature sender in the head?
Old Apr 8, 2017 | 03:46 PM
Alan 71's Avatar
Alan 71
Hi R,
What year car?
In 71 the sender wire for the gauge is part of the forward lighting harness.
It leaves the harness near the wires for the alternator.
The wire is protected by a woven sheath.
The connector varied depending on the configuration of the sender.
Regards,
Alan
Old Apr 8, 2017 | 04:07 PM
Rustman's Avatar
Rustman
Actually its not even for a C3. I was just wanting to use the driver's head port to put a sensor and was seeing what the factory might have done if the wire came from the back of the motor direction.
Old Apr 8, 2017 | 06:44 PM
DUB's Avatar
DUB
SO I guess you got it figured out??? The wire for the temp sending unit or 'whatever' is in the harness for the forward lights and alternator wiring and runs along the inner skirt and then goes over to the sender/sensor as Alans photos shows. And it also has a coated sleeve material to protect the wire from heat.
DUB
Old Apr 8, 2017 | 07:41 PM
sunflower 1972's Avatar
sunflower 1972
The sender wire is green.
Old Apr 8, 2017 | 08:20 PM
Rustman's Avatar
Rustman
I haven't figured it out yet.
My car is a 66, but I am installing an EFI system and need to run another coolant sensor for the ECU. Since I have 68 heads on the car, I figured I would use the sender port in one of the heads. In fact, when I got the car some years ago, the temperature gauge was hooked up to a sender in the driver's side head, but for the life of me, I can't remember how the wire was run to it; along the top of the intake/head somehow or maybe underneath.
I was just wanting to mimick the C3s, but didn't know the temp wire can in from the side via the headlight wires. Is it that was for all C3s, or did any 68-70 run it differently?
Old Apr 9, 2017 | 06:56 PM
DUB's Avatar
DUB
The temp sender wire ran the same from 1968 to 1982. On the mid years the wire can from the back of the engine and ran across the top of the valve covers where the left side is bolted and there are usually clips made into the valve cover that would hold the protected wire.
Post a photo of your intake if you care to do so.
If you are needing to install a sensor for the ECM...I do know that GM installed this sensor in the very front of the intake....where it is pointing towards the front of the car. It is installed in the water jacket of the intake where coolant feeds the thermostat and also fed the front of both cylinder heads.
DUB
Old Apr 9, 2017 | 11:42 PM
Rustman's Avatar
Rustman
DUB
Here are some pics from each side. It's a 63-65 FI intake, so stock there is only one provision for a sender (occupied my the factory temp sender for the gauge) unless I weld in another. I guess I could do without the bypass, but its already there so that is why I was looking at the heads.
Old Apr 10, 2017 | 07:15 PM
DUB's Avatar
DUB
Thanks for posting a photo of what you have going on.
Here is a thought...just in case you do not want to use the cylinder head to install your temperature sender for your gauge.
Keeping your factory temperature sender where it is.
You can possibly replace the nipple fitting in the intake where your heater hose is attached and replace it with this one and modify if by drilling a hole on the side of the hex portions and silver solder in a fitting that would accept your new temperature sensor for your ECM. This fitting might allow you to directly thread your new sensor into it..but that is hard to say.
http://www.ecklerscorvette.com/corve...1963-1972.html
DUB
Old Apr 10, 2017 | 11:20 PM
Rustman's Avatar
Rustman
Thanks, I'll keep that idea in my hip pocket in case I can't use the heads.
Old Apr 11, 2017 | 12:32 AM
bazza77's Avatar
bazza77
just an idea for the dash gauge unit .
http://www.ebay.com/itm/GM-336790-TH...-/182499532013
Old Apr 11, 2017 | 11:08 AM
c3_dk's Avatar
c3_dk
I have a friend that has a 71
He has a temp sensor in each head, the one in the driver side, is like mine 69 with 1 wire.
But in the pass. side, he also have one, but with 2 wires, what is that?
Old Apr 11, 2017 | 07:05 PM
DUB's Avatar
DUB
I am sure it is an automatic transmission and has to do with the transmission functions that GM had in place for that era.
DUB
Old Apr 12, 2017 | 12:17 AM
c3_dk's Avatar
c3_dk
DUB
Yes it is a 350/270 auto, and air car.
To Temperature sender wire routing
