EFI conversion question
Hi all,
I am about to install Sniper EFI on my car.
I have a MSD billet dist, question is, should i keep the distributor as it is with vac advance and weights, or lock it and use the built in ignition control in the sniper?
Anyone here done this?
I'm not running the sniper but another system and am letting the ecu control the timing. Locked out the MSD unit and it works flawlessly. I have a forum members car in the garage right now and will do the same. Much better to let the ecu handle it.
I did not get my Sniper as promised...
Apperently Holley has promised to much and cant deliver, tried to get it elsewere but it is a no go everywere....
stingraymax (04-27-2017)
Not to thread jack, but how is everyone driving the tach with an electronic distributor? Did you convert the tach to electronic as well? If you did, did you use the kit that Wilcox has or another. It that a good kit?
To the op, yes, definitely let the EFI unit control the timing. Assuming you can get the tach to run electronically somehow...
Brooklinite (03-23-2018)
73racevette (04-27-2017)
Strange thing... i have tried since christmas to get one through contacts with no luck.
Then i tried to order it from Summit, 2 weeks later i got it....
Masterkit was a no go, but when i orderded a Sniper and a fuelkit separate i got it!!
Finally my Holley Sniper is in place and with the electric fuelpump that came with it, had a mechanical pump previously so it was quite a bit of work to install it, but with all parts from Holley it worked out just fine, first startup tomorrow, exited is an understatement!
Tach being fed from MSD 6...
I have an electric tach and I get the input to it from my MSD-6a. I did have to remove the "tach filter" because otherwise it would get bouncy. (I am using EZ-EFI 2.0 with a locked MSD distributor and an MSD-6 ignition box).
Finished with my Snipr EFI install!
Feels like a completly new car with 100hp more.
Throttle response is insane, it surprised me so at first testdrive i spun the wheels.
You wont belive the difference!
For you guys out there thinking about this all i can say is: Just do it!!!!
Worth every dollar spent!!!!!!!!
The following 2 users liked this post by clwi:
Metalhead140 (06-10-2017),
NewbVetteGuy (08-04-2017)
What did you do for the fuel pump/fuel lines?
I use the pump that came with the kit from Holley, its a inline pump mounted on the hose from tank and not noisy at all.
Made a new feed line to the Sniper and used the old one as returnline to the gastank.
Did you run new fuel line? I ask because I should replace my SS flex line one of these days.
If new hard fuel line --- were you able to do it with the body in place?
