Crossfire help
Old Apr 10, 2017 | 09:49 AM
Tomjacksonn@live.com's Avatar
Default Crossfire help
I know there have been many pots on the subject, but I was hoping to get some help on my 82 collectors edition. It runs for about 20 seconds then dies. It does this same thing every single time, time after time. I cant drive it at all. I hooked up a timing light, and the timing bounces all over the place. I can never get it set to 6 BTC or anything really. I have done checks for vacuum leaks, replaced coil, cap, ignition module. The only code it throws is 12 and that is normal. I really hate throwing parts at it without really knowing whats the problem. The car only has 28,000 miles on it and has been a top flight NCRS car for years.
Old Apr 10, 2017 | 11:28 AM
MelWff's Avatar
MelWff
have you done a fuel pressure test?
Old Apr 10, 2017 | 02:23 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
OK, I have to ask. Do you have a GM Shop Manual? If not, get one. It's the only way to troubleshoot your motor reliably.
Now for a hint on timing. Did you disconnect the EST wire before you started to check the timing? If not, and you start turning the distributor, the ECM is still controlling the timing and you will NEVER be able to set the timing properly. All you want to do is check base timing anyway and set it at 8* - 10*. I know, the book says 6*, but you can go 8-10 as long as the motor doesn't ping. The GM Shop Manual is your best friend on a 35 year old car.
Also, like mentioned... CFI motors are rather fuel pressure sensitive. You need to know where your FP is set. Check it and set it to 13psi and you'll be happy with the results on a stock motor. OBTW, that's in the manual as well.
Old Apr 10, 2017 | 06:42 PM
terry82's Avatar
terry82
if it starts and runs for 20 seconds, its not timing.take off the air cleaner and look to see if injectors are working .I would think fuel pump.
Old Apr 10, 2017 | 08:41 PM
Great ideas for sure. Yes I did disconnect the ECM wire before trying to set the timing. As for fuel, the injectors are are both spraying an umbrella shaped patterns. In fact it seems to me that the car is running very rich. I have not checked the fuel,pressure yet, as I am not seeing a lack of fuel. I will do a fuel pressure check next!!!! Thank you everyone��������
Old Apr 10, 2017 | 09:07 PM
terry82's Avatar
terry82
is the motor being flooded,with gas?then I would think coolant sensor.take alook at the plugs.
Old Apr 11, 2017 | 08:44 AM
I replaced the plugs with new AC Delco last week. I will check the coolant sensor this weekend. Thanks!
Old Apr 11, 2017 | 10:30 AM
7T1vette's Avatar
7T1vette
Is the computer not throwing any trouble codes for you to use in
diagnosing the problem?
Old Apr 11, 2017 | 10:53 AM
The only code it shows is 12 and that is normal.
Old Apr 20, 2017 | 12:13 PM
Sorry for the delay on this. I did a fuel pressure test and it holds a steady pressure of 8 poiunds. I understand it needs to be 11-13 pounds, correct? So I should replace the fuel pump? Would it be best to use the 82 fuel pump or a later year pump?
Thanks all!
Old Apr 20, 2017 | 05:01 PM
terry82's Avatar
terry82
you need a pump .I have had a 85-87 pump for 20 years .no problem.but others will say only use the 82 pump .if you use the better pump keep a eye on your thottlebodys for leaks . the added pressure can put a strain on the old gaskets.
Old Apr 20, 2017 | 08:31 PM
7T1vette's Avatar
7T1vette
If you put a later version pump on your car, you will also need to install a pressure regulator to keep from blowing the seals out of those throttle-bodies. I'd stay with the '82 pump...unless it is more expensive that the later version PLUS the regulator.
I had an '84 car which had exactly the same engine/transmission as the '82. I remember a similar problem with mine. It turned out that the airflow sensor heated wire had collected a lot of dust/etc. on it and that acted as insulation, keeping the wire from cooling due to airflow and making the ECM think it wasn't getting enough air. That caused it to lean-out and the engine would die. It ran just long enough to go into "auto" mode, then died.
Hope that's all it is for you, too. (Take big duct off the front of the sensor, then carefully brush off the sensor wire. Replace duct.)
Old Apr 20, 2017 | 09:29 PM
terry82's Avatar
terry82
sorry,,,,,,, but the crossfire has a map sensor not a maf sensor
https://en.m.wikipedia.org/wiki/MAP_sensor there is no wire to clean.the regulator is in the rear throttle body
Old Apr 21, 2017 | 10:34 PM
lionelhutz's Avatar
lionelhutz
I would pinch off the return line and see if the pressure rises first to make sure it's not the regulator.
Old Apr 21, 2017 | 10:48 PM
7T1vette's Avatar
7T1vette
Your response clarified my memory. It was NOT my '84 C4 that had that problem...it was an '85 Olds Cutlass Supreme (3.8L) with that problem. Sorry. At the time I read your post, my [30-year-old] memories went to that C4...MEMORY ERROR!
Old Apr 22, 2017 | 11:59 PM
Buccaneer's Avatar
Buccaneer
I pretty sure a MAF sensors didn't show up on Oldsmobubbles until 88/89 for the 3.8, but I could be wrong, they were all MAP sensors.
Old Apr 23, 2017 | 06:41 AM
7T1vette's Avatar
7T1vette
Almost positive about it being that Cutlass (but not as positive as I used to be ).
Old Apr 23, 2017 | 09:42 AM
Bigredwing's Avatar
Bigredwing
Rich gassy smell, good fuel injector pattern, runs for a few seconds? Classic throttle position sensor problem. Check it with jumper wires and a multimeter. Do a search and you will find procedures and results. Good luck.
Fuel pumps also go bad. There are replacement pics and procedures on the forum too. Recommend doing a complete job by installing new ethanol resistant fuel injection strength hoses throughout the system. You will probably need to drop the gas tank to do that.
Old Apr 30, 2017 | 11:08 PM
Hi all
Finally got the new fuel pump installed, shows 12-13 lbs of pressure on the gage. Car barely ran, and was not even close to drivable. On a hunch I pulled the computer from the battery compartment and swapped out the PROM chip. That has solved the problem from what I can see from several test drives today. Looks to me that a previous "mechanic" bent a couple of the PROM pins. Thanks for everyone's input...you just never know!
To Crossfire help
