When you put the nut on the ball joints and line up the hole in the castle nut, is the nut supposed to be loose? When I tighten the castle nut tight it goes way past the hole for the cotter pin. Thanks
Hi m71,
That surprises me…. I'd think even something from OR should work.
Did you run into this situation on all 4 ball joints?
The holes in the spindles haven't been enlarged in some way have they?
It's that interface…. balljoint shaft/spindle hole…. that has to be right.
Regards,
Alan
Hi m71,
Regards,
Alan
I just tried the upper one from OR, it was a 1/4 longer than the original one. I don't think the holes have been enlarged because it worked fine on the old ball joints. It was tighten farther up than the original, so the hole for cotter pin was below the nut.
You "could" use a washer or two under the nut to get the hole lined up.
