1969 C3 door question
Can someone confirm that my early 1969 roadster internals and window can be moved over to this door without any problems.
It looks like the metal bar is pretty beefy and takes up much of the inside door space.
Thanks, Pete
but I have used reinforced door with 69, regulators, and rails.
you can also interchange the early late window channel/glass.
I was hoping someone had done the change over without issue. The guy once worked at a GM dealership and said it was listed as a 69 - 77 corvette door so I guess a little more protection on the drivers side will not hurt.
As always, thanks Alan!
Pete
Here's my 71 door.
Am I seeing a difference in the area of the fastener (screw) for the top of the interior door 'pull'?
Regards,
Alan
The part tag says 14019979 which shows 1969 to 1977 corvette door but perhaps the tag is incorrect. I will try to find a part number on the actual door itself.
If worst comes to worst I will cut my present door pull handle support and weld it in place on the new door. It is mainly the side metal where the side striker latches that is creased on my old door so hopefully I can make this new door work since it is in such nice shape. I will have to check carefully that the rest it the same.
Though I am not a great welder, I can weld.
Thanks Alan for your keen eye. My interior panel is on the door at the moment so I will have to remove it to compare properly.
Pete
It could well be that the new door will work…. perhaps you won't know for sure until you try.
I don't think though that the beam itself will be a problem…it might be some other small detail.
In my mind I've always 'lumped' 69-77 doors together too.
Regards,
Alan
Regards,
Alan
I will use whatever part of the old door that I need and cut and weld it too the new. I was quite surprised to find how difficult it was to locate a clean rust free 1969 door.
Do you have any idea where the part number is located on a door. I see nothing!
Pete
I'm unaware if there's a part number on the doors or not.
I've not had occasion to look/search for one so there could be.
Perhaps someone else knows?
Often when a part became a 'service replacement' part the part could be physically 'different' than a 'preceding' original or service part but the variation didn't prevent the new part from being a satisfactory replacement.
An example would be a spare tire tub….. for years the tubs have been available from dealer parts departments…. but the tub you get isn't made from the the dark fiberglass that the tubs were made from during 68-72.
This difference doesn't stop it from being a viable replacement to most people.
Regards,
Alan
