Vent Door Removal
Old Apr 18, 2017 | 02:50 PM
Cavu2u's Avatar
Cavu2u
Default Vent Door Removal
On my '73 Coupe, Passenger Side Foot Vent.
The seal is naturally shot after 44 years (broken section marked), so I wish to remove and replace it. Easier with the Door out of the car I'm assuming, so How is the door removed?
I lifted the Door UP, compressing the Spring as much as I could, but the lower pivot stud still doesn't clear out of it's hole.
Am I missing something?
Thanks much for any thoughts.
Steve
Never mind. I got it. It just required more force, and I took a chance of breaking something in using it. Pried the door up at the bottom with a large screwdriver, and it was up enough to "walk" the bottom pivot out of it's hole. then took the screwdriver and "chiseled" it off the edge and freed the door that way.
Got some rivet R&R to do here also.
Steve
Old Apr 18, 2017 | 03:49 PM
Alan 71's Avatar
Alan 71
Hi Steve,
If you look at the plenum itself you'll see there's a shallow recessed track molded into the fiberglass that makes it easier to get the door out and back in….. once you realize it's there!
Too old to remember if it's at the top or bottom… I'm thinking... top.
Regards,
Alan
Just remembered... (Glad you weren't drowning while I was looking for a life preserver!)
Look at the top of the plenum… there's actually a 'ramp' that leads up to the hole for the sprung pin. To install you put the pin in the bottom hole, tip the top of the door completely into the plenum and then pull the top of the door towards the interior of the car. This movement compresses the sprung pin on the ramp until it's below the hole and then the sprung pin pops into place.
Old Apr 18, 2017 | 05:28 PM
CanadaGrant's Avatar
CanadaGrant
Hi Steve,
To remove or install that door you don't pry it up against the spring loaded pin as all you are doing is deforming the vent itself and they can break. All you do is pull down on the exposed end of the spring loaded pin until it releases and clears the mount hole, angle the door in and lift the bottom fixed pin out of the other hole. The pin is spring loaded so it can be removed.
Old Apr 18, 2017 | 05:33 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by CanadaGrant
Hi Steve,
And you drill out the rivets.. go find you some flat thin rubber.. put it between the halves and then trip around it 3/8"... or buy the seal kits.. lol. You should be able to find some rubber at your local parts store and the two halves just rivet back together.
Willcox
Old Apr 18, 2017 | 07:14 PM
Cavu2u's Avatar
Cavu2u
Originally Posted by Alan 71
Hi Steve,
Regards,
Alan
HA! I did it ***-backwards Alan.
And like Grant said, I was lucky nothing broke.
I did get the rivets out; they were extremely tight in the spots where they held hardware in place, but very loose (rotated) where they just sandwiched the seal.
Speaking of the seal....
... they remind me of my wetsuit, only a tad thinner. Kind of a foam, more so than a rubber type. You say there's a Seal Kit available Willcox?
Thanks again guys.
Steve
Old Apr 19, 2017 | 07:44 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
You can find sheets of craft foam at Jo-Anns fabrics or any of the craft stores that you can cut seals from.
I used that when I rebuilt mine years ago, and it is still working today.
Old Apr 19, 2017 | 07:54 AM
Cavu2u's Avatar
Cavu2u
Thanks much. I'll hit some of the local craft stores and see what's available. Did you just use 1/4" Pop Rivets for assembly?
Thanks again.
Steve
Old Apr 19, 2017 | 10:25 AM
0Willcox Corvette
Former Vendor
Thanks again guys.
Steve
https://willcoxcorvette.com/corvette...seal-kit-68-82
I still use regular pop rivets vs the original style.. .you can't see the door once it's installed and unless we're doing a ncrs car most don't care.
Willcox
Old Apr 19, 2017 | 10:29 AM
VancouverL71's Avatar
VancouverL71
Thanks for the great pics Cavu,
This is another job I have on my horizon. It will be much easier after reading your great post and seeing the close up pics.
Cheers, Pete
Old Apr 19, 2017 | 11:23 AM
c69vete's Avatar
c69vete
St. Jude Donor '07
Thanks again.
Steve
Yes, I did use pop rivits, 1/8th with the back up washer on the other side as the metal on the doors is so thin.
Old Apr 19, 2017 | 03:25 PM
Cavu2u's Avatar
Cavu2u
Willcox
Willcox,
I did find a sheet of thin foam at a local hobby shop. Coulda bought it in RED, BLUE, YELLOW, PURPLE, but dull ole me got BLACK.
Steve
Old Apr 19, 2017 | 03:30 PM
Cavu2u's Avatar
Cavu2u
Alrighty then: pop-rivets it is. And yeah, I was figuring on probably having to use washers. (Wonder what gauge steel that thin stuff is anyway.)
Steve
Old Apr 19, 2017 | 03:35 PM
0Willcox Corvette
Former Vendor
Steve
They will work just fine.
Old Apr 19, 2017 | 03:47 PM
theandies's Avatar
theandies
Mine after cleanup and paint before installing the seal:
I did this a few years ago. Had do do some repairs as one of the hinge pins was almost falling off. Makes a world of difference when driving on those cool morning or evenings. I used pop-rivets and back the seal side up with some thin washers.
Old Apr 19, 2017 | 07:11 PM
Cavu2u's Avatar
Cavu2u
Yeah it's amazing that a little time and effort yields such a dramatic change in condition. Those came out great.
I went to Home Depot expecting to find #4 Washers for these little Rivets, but all I could come up with is, dare I say, Metric M3 size!
But they fit the rivet diameter perfectly!
Now to accurately cut the foam around the plate to leave a decent sealing lip. This seems easier than cutting out the seal first and then try to perfectly center it between the two plates. At least I could tell you how that would come out if I tried to do it.
Steve
Old Apr 20, 2017 | 12:03 PM
Cavu2u's Avatar
Cavu2u
Default Vent Door Installation
This was the easiest way I found to put the door back in.
Once reworked (talcum powdered the seal for smoothness, and the great smell of lilacs too ), ....
... I positioned the upper pivot pin like this.
Placed the door into it's lower pivot hole, while smoothing it's seal position.
Then aligned the Door's pivot hole with the car body's pivot hole.....
... and then pushed the pin into it's pivot position.
And that's about it.
No Rocket Science here. Just my experience with this step.
Steve
Old Apr 20, 2017 | 12:09 PM
Alan 71's Avatar
Alan 71
Hi Steve,
Nice Work!
And.. nice information!!
I think there's a certain pleasure gained from doing something well even though it won't be seen until the car's apart again…. someday!
Regards,
Alan
To Vent Door Removal
Old Apr 20, 2017 | 12:48 PM
Cavu2u's Avatar
Cavu2u
Hi Steve,
Nice Work!
Regards,
Alan
Yes Alan,
There is indeed a satisfaction gained.
And it also comes in the form of a rather unchanged bank account balance.
Thanks for the kind words.
Steve
Old Apr 20, 2017 | 01:21 PM
theandies's Avatar
theandies
Not seen but felt on those cool mornings. I think of this job every time I open and close mine.
Nice job.
Old Apr 22, 2017 | 09:30 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
Nice job.
