engine stand question
Old Sep 27, 2002 | 10:03 AM
78pace's Avatar
78pace
Default engine stand question
going to start pulling motor in a few weeks how much would you say a sbc
motor weights? they offer 750 lb stands 1000 lb etc thanks :cheers:
Old Sep 27, 2002 | 10:47 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: engine stand question (78pace)
Regardless of the weight I always buy the heavier of the 2. I always go for the 1000 lb engine stand. When you start torquing the heads or anything I feel better with the slightly more expensive 1000 lb. stands. I have bought 4 of them on sale.
Old Sep 27, 2002 | 10:51 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: engine stand question (norvalwilhelm)
Yea the little ones are pretty scarey.
Even with the 1000lb ones they bounce around pretty easily..
Old Sep 27, 2002 | 11:09 AM
fauxrs's Avatar
fauxrs
78 L-82 complete with fluids - 640.7 lbs
78 L-48 complete w/ fluids - 622.4 lbs
does not include a/c or other options - this is just the motor.
Old Sep 27, 2002 | 11:22 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: engine stand question (fauxrs)
Make sure you get a 4 wheel model, the 3 wheelers are scary,.
Make sure you get some quality fastners, at least grade 8 or so to secure the engine.
Marck
Old Sep 27, 2002 | 11:34 AM
Fevre's Avatar
Fevre
I have a 3 leg light dty one and it is a bit scary. When I do any type of heavy torquing I rotate the engine so I am pulling up on the bolt. ie When torquing the heads I place them on witht he engine level then hand tighten a bolt or two then rotate the engine so the heads are perpendicular to the ground and pull up on the wrench so I am lifting the engine up not pushing it down. Not sure if it makes a bit of diff but it sure makes me fell better.
BTW Use grade 8 bolts to attach the engine to the stand. The bolts are what scare me the most, not the stand itself.
Old Sep 27, 2002 | 11:39 AM
Anar76's Avatar
Anar76
Default Re: engine stand question (Fevre)
i have a 3k pound stand, with 5 wheels.
nice and secure, doesnt bounce, bearly moves when i work on the engine.
I love it.
I should have bought a couple more when I bought this one.
To engine stand question
