Oilpump exchange during engine rebuild?
Old Apr 25, 2017 | 03:00 PM
Günther-C3's Avatar
Günther-C3
Default Oilpump exchange during engine rebuild?
I´m wondering if I should exchange the oilpump during the engine rebuild. The old one works, but don´t know about the milage.
Should I keep the "old" one or rather buy a new one?
If new one, high volume or not and which brand preferably?
Old Apr 25, 2017 | 03:09 PM
domenic tallarita's Avatar
domenic tallarita
Oil pumps seem to be the first one replaced when rebuilding, but I look at the gears and any possible wear. If all looks good then you can shim the relief spring about 1/16" to get a few more lbs of pressure.
I will get a bunch of slack on what I said, but the pump is always running in oil.
I have never seen a oil pump that didn't work, maybe a few lbs less but still pumping.
Many will say why not spend the extra $, but if your pressure was OK then take a good look at your old pump.
Dom
Old Apr 25, 2017 | 03:20 PM
Big2Bird's Avatar
Big2Bird
I would use a stock Melling unit. $100. Use a metal collared pump shaft extension. NOT the nylon one. $10.
Old Apr 25, 2017 | 03:52 PM
Gordonm's Avatar
Gordonm
Your spending all that money on new parts and a quality rebuild, a 100 dollar pump is cheap insurance. Replace it.
Old Apr 25, 2017 | 03:53 PM
Günther-C3's Avatar
Günther-C3
High volume or standard?
Old Apr 25, 2017 | 04:04 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Never use a standard volume pump on a stock engine.
And if you spent $100 for one, you paid four times too much.
Remove the spring out of a stock M55 Melling....stretch it a bit.....massage the rear main cap by radiusing the inlet....then buy a quality 4340 stud to fasten it to the cap.
This is all you will ever need up to 6000rpm....and beyond.
Jebby
Old Apr 25, 2017 | 04:17 PM
Gordonm's Avatar
Gordonm
Jebby
I thought the same after I replied to it. I think I paid like 45 for a Melling pump recently.
Old Apr 25, 2017 | 08:00 PM
Big2Bird's Avatar
Big2Bird
Jebby
Huh?
Old Apr 25, 2017 | 08:10 PM
drwet's Avatar
drwet
This is one of those threads where you are going to get a hundred opinions. So I might as well give you a couple of mine. If the engine is built correctly, there shouldn't be any need for anything but a standard volume and pressure pump. A high volume pump can help with an engine that is getting a little tired and the clearances are starting to get a little large. I don't know what the indication is for a high pressure pump. So if you are going with a stock pump, then do you need to replace the one you have? I've never seen an oil pump fail in a Chevy. I'm sure it happens, but I've never seen it. Given the quality of the parts we are getting nowadays, I would think long and hard before I replaced the one you took out that you know was working. Was it making good pressure? If you do replace it, make sure you buy a name you trust.
Old Apr 25, 2017 | 09:31 PM
68notray's Avatar
68notray
I agree - std volume and pressure are not just fine but PREFERRED. HV/HP pumps just put undue strain on the pump drive shaft, scatter your ignition, and empty your oil pan.
Old Apr 26, 2017 | 04:07 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by Big2Bird
Huh?
Ooops.....
Never use a High Volume......on a stock engine.
Jebby
Old Apr 26, 2017 | 04:08 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Exactly right.......if the holes in the block are not enlarged to accommodate it and the bearing clearances are not wide enough it is a waste.
Jebby
Old May 2, 2017 | 07:41 AM
Günther-C3's Avatar
Günther-C3
Where do I get this metal shaft extension?
Old May 2, 2017 | 07:54 AM
Big2Bird's Avatar
Big2Bird
You can purchase the pump and extension via Jegs or Summit Racing.
Old May 2, 2017 | 10:00 AM
jb78L-82's Avatar
jb78L-82
I used a Melling standard volume, standard pressure pump when I rebuilt/upgraded the L-82 in 2014. I use Mobil 1 0W-40 European Formula synthetic and my oil pressure at start up cold is 70-80 lbs at 50 degrees ambient and 45-50 lbs at idle hot and 60-65 lbs at high rpm....
Old May 2, 2017 | 10:11 AM
carriljc's Avatar
carriljc
Default oil shaft with metal collar...here you go..
under 10 bucks
https://www.summitracing.com/parts/mel-is-55e
Old May 2, 2017 | 10:22 AM
GOSFAST's Avatar
GOSFAST
Hi Gunther, all you need is a conventional Melling M-77 pump with an M77020 spring installed.
Use a "steel-sleeve" driveshaft, no "nylon-sleeves"!
Thanks, Gary in N.Y.
P.S. We buy these components in bulk and put the package together in-house, we call it an M77-A pump here, it's the one Melling never produced. Can't tell you how many times I've recommended to my good friend George R. at Melling to consider offering this in their lineup!
Old May 2, 2017 | 10:41 AM
7T1vette's Avatar
7T1vette
Open the stock pump up and inspect it. If it is clean and doesn't have scoring on the bearing [plate] surfaces, it is fine to reuse for a stock motor with normal use.
You can stick a high volume pump in a stock motor...but it will just work hard to pump more oil through the same passages. It won't IMPROVE the lube capabilities of the stock pump (most surviving vintage Chevy cars have/had pumps that worked fine for 40 or more years WITH NO PROBLEMS). What would make you think that any other brand of pump would do better than that?
If you NEED a high volume/high pressure pump, go for it. If you don't, keep what you have, but replace the plastic tube before install.
Old May 3, 2017 | 10:38 AM
cv67's Avatar
cv67
St. Jude Donor '05
Next motor will get a std volume high pressure pump
HV pumps are hard on the distributor gear
Ask your machinist to work over your oil passages, imo in most builds thats all you need. Esp if you run a heavier oil
To Oilpump exchange during engine rebuild?
