Valve Lash?
Old Apr 26, 2017 | 05:11 PM
Vettesic's Avatar
Vettesic
Default Valve Lash?
Has anyone adjusted valves while engine at op temp running? As opposed to a manual adjustment. Ive seen it done once on a small block in a boat. There are some Utube videos out there on the subject. Basically, Just want some feedback on it....
Old Apr 26, 2017 | 06:33 PM
Vettesic's Avatar
Vettesic
Originally Posted by JoeMinnesota
If you have a particular reason for wanting to do this (like a noisy rocker/lifter) and it is a stock valve train with press-in studs, good idea to eyeball or run a straight-edge across the tops of your studs, just to make sure nothing is pulling out or out of place.
Ive noticed that valves have been ticking at higher rpm. Prior owner did install a mild cam / lifter set. I believe all else stock. Hoping to quiet them down with an adjustment. I will look for levelness of the studs.
Old Apr 26, 2017 | 09:28 PM
lars's Avatar
lars
There is no good reason to adjust the valves with the engine running. Do you think the factory adjusted valves on the assembly line with the engine running? With hydraulic lifters, set the valves correctly with the engine off and cold. There is plenty of pre-load on the lifter to compensate for any temperature changes in the engine. If the valves clatter once warmed up, and the valves have been set cold with correct pre-load, you have other problems.
Solid lifters should be set cold with the engine not running, then checked again, with the engine hot and not running, making any minor changes needed.
No professional engine builder sets valves with the engine running.
Lars
Old Apr 26, 2017 | 11:44 PM
Vettesic's Avatar
Vettesic
What is the best method for finding TDC? Also what is recommended turn to set lifter once at zero Lash obtained on a cold motor?
Old Apr 27, 2017 | 10:04 AM
73racevette's Avatar
73racevette
Finding TDC for lash setting does not have to be super accurate. Just have to be within a few degrees. Use the timing marks and be sure you are on the right stroke. Put your finger over the #1 plug hole and be sure it is the compression stroke as it comes up to TDC. Once at the timing mark you are close enough for setting lash.
Old Apr 27, 2017 | 11:56 AM
MelWff's Avatar
MelWff
Default Chassis Manual
If you dont have a copy of the factory Chassis manual it would be a good investment.
Pull off both valve covers. Note on your distributor cap where the #1 and #6 cylinder wires are located. Remove the distributor cap. Remove all the spark plugs.
Turn the crankshaft till the rotor is pointing to the #1 cylinder wire location.
Adjust Exhaust 1,3,4,8
Adjust Intake 1,2,5,7
Rotate the engine so that rotor is pointing to the # 6 cylinder wire
Adjust Exhaust 2,5,6,7
Adjust Intake 3,4,6,8
You are adjusting for zero clearance plus 1/2 turn
Old Apr 27, 2017 | 12:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
if youre not confident in doing it right wiht the motor off theres nothing wrong with doing while running in fact makes it easy
Back it off til you hear clacking, slowly tighten til it gets quiet then do your 3/4, 1 turn etc. Pretty foolproof.
I heard somebody actually sells the valvecovers with holes already in them so you cna do it without making a mess.
If its a solid cam youll have to do it wiht the engine off
Old Apr 27, 2017 | 07:05 PM
Vettesic's Avatar
Vettesic
I've actually made a makeshift valve cover you speak of from an old valve cover. Just cut out mid section with a dremmel tool. I'll go with the cold adjust at this point. As stated I've seen it done while engine running with good results. Melwff method sound good. Thanks.
Old Apr 27, 2017 | 07:46 PM
jim2527's Avatar
jim2527
Lars
Lars,
I've seen 2 different write ups for setting lash cold with engine off. One method involves many turns off the crankshaft while the other only requires one. Is either sufficient?
Single turn method once #1 is at tdc:
https://www.jalopyjournal.com/forum/...valves.168345/
EDIT: skipped over melwiff post#6....
Old Apr 27, 2017 | 07:48 PM
73racevette
Both are fine. Some choose to adjust each cylinder one at a time, others do the cylinders out of order. Same end result. One just takes more concentration to be sure you are adjusting the correct cylinder at the right time.
Old Apr 27, 2017 | 07:51 PM
jim2527's Avatar
jim2527
Thanks. I last did mine as posted in the link above. I found a handy valvetrain 'map' to print!!
Old Apr 28, 2017 | 12:32 PM
jim-81's Avatar
jim-81
When I did mine, I used started with cyl 1 and did that one, then rotated the crank 1/4 turn (my harm. balancer is marked) and did them in firing order. Only requires two revs of the crank.
Old Apr 28, 2017 | 12:38 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Iused Lars" write up for my LT1 motor, it works great with solid lifters, not sure about hydraulic lifters. With hydraulics I always did it with the motor running
Old Apr 28, 2017 | 04:07 PM
Vettesic's Avatar
Vettesic
I was able to adjust valves this morning. Followed Melwff's procedure and with the help of Jim2527 chart it was quite easy. Did oil change and so far no tapping. Happy camper right now
Old Apr 28, 2017 | 04:28 PM
MelWff's Avatar
MelWff
excellent, glad to hear that. I just copied it from the factory manual.
Old May 26, 2025 | 03:14 PM
Vettrun's Avatar
Vettrun
My Gearhead friend, who’s also an automotive engineer and messing with motors all his life helped with my valve lash settings. We used a drill coupled to an old modified distributor bottom. It was easy to see and insure all the lifters were pumped up properly.
After the cold set, we unfortunately had one still making a bit of noise. This time, using the covers, we warmed the engine close to regular temp but not so as to burn ourselves accidentally.
It went fine! No burns and most importantly, no cuts.
To Valve Lash?
